Results 1 to 13 of 13
Thread: CYA not registering
    CYA not registering
    I have a new pool 18X40 Sharkline Oval (17500 gals.) that we just got filled a week ago. When I filled it the PC told me to get CYA from 0 to 40 would require about 4lbs of stabilizer which I added. I finally got a Taylor 2006 test kit and I'm still not getting any CYA. Should I add more stabilizer or does it take awhile to register?
    Thanks Jim
    17500 gallon Sharkline Morada PUR RTR 18X40 54 tall, 1.5 Hayward cartridge filter,
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: CYA not registering
    an ideal range is between 40-70ish... right? you could go another 4 pounds and that should bring you to around 55
    the test kit that uses turbidity is easier to read once it's past 30 in my opinion.
    Don't forget that CYA needs about a week to fully integrate before you test. And don't backwash it prior to that or you might throw some of it out your waste line
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    CYA can take up to a week to fully dissolve and show up on the test. Also, the test is not so good at measuring low levels, so the actual level could be as high as 20 and show up as zero on the test.
    X-PertPool, the recommended range for a SWG pool is 70 to 80, while for a non-SWG pool it is 30 to 50.
    38,251
    4lbs of stabilizer in a 17500 gallon pool will raise the CYA by 27ppm. This could very well still show close to the minimum of the test.
    I would add another 2 lbs and assume you are at about 40ppm. It can take up to a week for the CYA to show up on the test.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Jbliz beat me...
    Poolcalculator gives my 93 ounces by weight to raise your 17500 gallon pool to 40 ppm cya. 64 ounces (4 lbs) would only raise you to 27 ppm cya, which is harder to measure. Also, cya can take up to a week to show up fully in tests.
    Thanks for the responses I will add 4 more lbs wait a week and re-test. I am having trouble holding FC and I suspect its because my CYA is not at adequate levels yet.
    38,251
    we both said 2 pounds why are you going to add 4 more?
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Dont know why I said 4, I will add 2 thanks again
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I said 4 because I like an argument. lol
    I guess it would be good to find out if he had a SWG or non SWG
    Regardless wouldn't 4 more pounds take him to around 55? which would be at the max range for a non swg thus making it fairly easy to read on that turbidity kit.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    38,251
    Good point on the SWG ... no mention, so assumed it was not.
    55 is a little on the high side to start, especially if they end up having to go through the shock process.
    Just a little safer to start low I guess.
    Non SWG, just added about 2lbs tonight we will see what we got tomorrow.
    Thanks again JIm
    38,251
    The CYA may not show up on the test for a week.
    Just assume you are about 40ppm until you can test it next week.
    Checked this morning still not registering anything although I think the sample looks a little cloudy. I will give it a week before adding any more.
    Thanks Jim
