Thread: Cut Liner
    Cut Liner
    I have recently noticed water puddling outside my above ground pool. I investigated inside the pool near this area and see a small L shaped cut in my liner and the patch I applied to a similar cut about 4 years ago is starting to come undone. I removed the old patch and have tried unsuccessfully to apply a vinyl patch with a basic pool patch kit by hth. I tried a few different patches but none of them adhered. The liner is wrinkling in many spots throughout the pool and is particularly wrinkled in the area of these 2 cuts. I can't flatten the liner and apply the patch at the same time. Does anyone have any other solutions or am I looking at having to replace my liner?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Cut Liner
    Welcome to tfp, dugm
    If this is on the floor I would try to remove the wrinkles where the leak is before applying a patch. some people have had luck doing this with a toilet plunger. Then once the patch area is wrinkle free, retry patching.
    Re: Cut Liner
    It's on the wall of the pool, not the floor.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Cut Liner
    Patch the pool with actual vinyl (like from a waterbag) boxer 100 glue works well, and so does HH-66. Anderson sells a flexible sealer that works well for sealing the edges of the patches when they start to curl up. http://store.leaktools.com/mm5/merchant ... y_Code=EAS
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
