Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: Buying House with AG pool, Need Advice
    First of all I want to say I am extremely happy I found TFP.
    We are closing on a house in Maine in a couple of days that has an 18'x33' AG with a large surrounding deck. The pool has not been maintained yet this season and is extremely green. I see a great post on how to go from swamp to oasis and plan on reading that once I have a good idea of what I need to do beforehand.
    The pool liner has a couple of tears above the full waterline, so first of all, does anyone know if this is repairable enough to be able to use the pool for the remainder of this summer? If I can't, I won't even get started. If I can do some kind of temporary repair, at least enough to get the filter going and get the water from green to blue for the short remaining summer, I'm sure I'll have more questions.
    +-18Kgal. AG, Sand: Hayward s-180T 3/4hp pump
    Pool installed 2004?
    Feb 2008
    Denton, TX
    5,061
    Re: Buying House with AG pool, Need Advice
    Welcome to TFP!
    You probably need to go ahead and price out a new liner. It is hard to say when it is going to "give" and turn your yard into a swamp.
    38,305
    Too late to include a new liner in closing costs?
    Yeah, too late for that, it will come out of my pocket. Is it even worth trying to clean or should I just drain it?
    38,305
    I would almost say drain it ... but then you have the danger of a giant hole in the ground that someone could fall in to.
    You could certainly get it clean with some work and maybe get some use out of it this year ... I am not familiar with liners, sounds as if it could completely rip open at some point.
    Not so worried about the big hole, but I would be concerned about messing up the ground under the pool and have to rework that before a new liner goes in. And that probably would happen if the liner gives out. The back yard has a downward slope, so its hard to say what would happen. I'll know more when I move in and can take a closer look. Its probably a **** shoot.
    I won't be able to replace the liner until next spring, unfortunately I have other projects that are a bit more important. I want to rework the decking and get it off the lip, if I can.
    Nice to know you guys are here to help, can't wait till I can contribute!
    ~Michael
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Snowmonkey517
    If you can't replace the liner till next year, then I would try and clear the pool this year and hope the liner lasts...I think it might. You could duck tape (I would use gorilla tape) the areas where it is separating and reinforce any other area that looks like it is starting to tear.
    Thanks linen, I'll give it a try and hope for the best.
    I used Gorilla tape to patch the sidewall tears. That works perfectly. Thanks for that bit of advice.
    I have followed the "Turning your Green Swamp" guide and the pool is cleaning up nicely. I am able to hold FC now. I am keeping it up to shock level until the algae dies. The water is cloudy as I expected, but its blue now and I will keep it at shock level and backwash occasionally until the water clears.
    All I have is a basic test kit at the moment. Planning on getting a Taylor very soon. The only way I have to test CYA is with a strip, and it shows very low even though I am adding stablizer in the "old sock". If my FC is holding above shock level
    for good period of time, the CYA should be close to normal? The only thing showing a little low(other than the CYA) is the PH.
    I will be replacing the liner next spring, so I'll have to start all over again but at least it won't be with green water and a ton of leaves!
    38,305
    Curious how you are holding at shock level if you do not have the FAS-DPD test?
    Backwash when the pressure rises 20-25% of the clean pressure.
    Glad to hear you are making progress.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    I doubt it was holding. I finally got a Taylor K2006 today, my water is still cloudy( almost 2 weeks since I started cleaning the swamp). I added about 1.5 gal of 6% bleach last night and ran these tests this evening.
    My test results:
    CYA- 37ppm
    FC- 0.4ppm (2 drops x .2)
    CC- 1.8ppm (9 drops x .2)
    PH- 7.5
    Ttl. Alk- 100ppm
    CH- 30ppm
    Any suggestions for getting the pool clear and keeping the clorine level up?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Snowmonkey517
    Do the shocking process. This will require a lot of bleach/liquid chlorine. Dose as often as you can to raise your FC back up to your shocking level (but no less than 1 hour between).
    By the way, you do not need to do the 25 ml sample for FC and CC. Save your reagents and do the 10 ml sample where each drop of the R-0871 is 0.5 ppm FC (or CC). See: http://www.troublefreepool.com/exten...1.html#p206393
    Great info! Thanks. I did the 25ml test because I didn't really know where I stood. I'll continue on with the 10ml tests.
    It doesn't really say in the Shocking Process doc, but should I still watch CYA, PH and all the others during the shock process?
    I'll start this process tonight and repost in a few days.
    Thanks again for the great info.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,777
    Hi there! Do you have a leaf rake yet -- that's like a skimmer net but with a deep net pocket. Have you checked to see if there's any debris, leaves, etc on the bottom? As my handle suggests, I recovered a foreclosure swamp -- though yours just sounds like a regular sale -- but you'll make much faster progress if you first ensure you've manually removed any debris, then maintain shock level at all times if possible, and be sure to filter 24/7.
    When you add cya, sometimes it doesn't show up in the tests for up to a week, just so you know. Let us know what kind of read you get, and best wishes!
    Ps - ph readings won't be accurate with Chlorine at shock levels/above 10 ppm. Cya reading you only really need once unless you're adding more -- once it's there, it's there, save losing a little due to splash out or occasionally overwintering having bacteria convert it to ammonia. So if you've added enough for your target level, you don't need to read (once you have a baseline reading.)
    The cya test is tricky, so if you want to practice, remember you can just keep pouring the same solution back into the view tube over and over until you're certain of your read.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Thanks Swampwoman.... house was a short sale (might as well have been a foreclosure!). The owner left and obviously didn't maintain the pool.
    I have both types of nets and have been using them daily. I have also vaccuumed 3 times but I am still pulling up occasional leaves. I found 4 masks, a snorkel and a pair of shorts but no body parts!
    Its hard because I can't see bottom yet, but its slowly getting better. I had a cheap-o test kit until my Taylor K-2006 arrived so the chlorine or CYA test was never accurate until now.
    My CYA is at 50 ppm today (no problems getting good read), PH at 7.5 and FC was at 10ppm after a dose of shock. (I am following the Shocking Process linen mentioned above.) So I gave it another dose of shock to get the FC up to 20ppm as the guide states.
    Following this:
    Shocking:
    Measure the FC level
    Add enough chlorine to bring FC up to shock level (or a little higher)
    Repeat steps 1 and 2 as frequently as practical, but not more than once per hour, and not less than twice a day, until:
    CC is 0.5 or lower;
    An overnight FC loss test shows a loss of 1.0 ppm or less;
    And the water is clear.
    Brush the entire pool once a day
    Backwash or clean the filter as needed
    Filter is running 24/7 through the process.
    I'll check it again in a few hours, probably shock it in the morning if needed, have the kid shock it in the afternoon and just keep going until we get the results. This whole process of going from swamp to oasis is pretty expensive, it would have been cheaper to maintain it. But when someone doesn't care, it doesn't matter.
    And to think I need to replace the liner next spring!
    38,305
    When you say you are adding a "dose of shock", what exactly are you using to add the chlorine?
    adding powdered pool shock following dosage directions on the package.
    38,305
    You will have to be more specific as there are 3 different chemicals it could be ... 2 of which add CYA quickly and you are already at the high end.
    Also, you need to review the shock process article in Pool School ... typically using powder chlorine and directions on packages is not what we recommend.
    Yeah, I see. Its Trichlor- increases the CYA. I have 6% bleach with no additives that I bought at Home Depot. Its a little cheaper than the shock.
    I'll use that instead, using the calculator.
    Thanks for pointing that out.
  20. Back To Top    #20
    Apr 2012
    SW Ohio
    456
    If you have a aldi's near you their generic bleach is around 1.25 per 96 oz bottle you may want to buy about 6 cases or so. You don't want to run out half way through the shock process.......Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
