Results 1 to 9 of 9
Thread: New to TFP, work at CAT Controllers
    Apr 2008
    Rockville, MD
    7
    Hello Everyone,
    I have been reading TFP to fill some of the gaps in my pool knowledge.
    I have only been in this industry for about a year, but I've had an in-ground 20k gnuite pool forever. I'd like to think i know a lot about ORP and controllers (and hooking them up to SWGs). I should, since I work at CAT Controllers and we make pH/ORP controllers. Im sure many of you know they are mostly for commercial pools, but its not unheard of to see one of our controllers on a residential pool.
    I think some of my coworkers will join too, this site is a great resource. Hopefully we can add to that.
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Welcome Andrew!
    We are always grateful for input from people with professional experience.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    I think I referred Andrew - where's my test kit? j/k - welcome andrew - glad to have another brain to pick on the site.
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Andrew ,
    We're glad to have you here.
    You're done SLAMing when:
    welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    Aug 2007
    Austin, TX
    341
    Welcome Andrew! I can't wait until I get one of your controllers for my pool. Looking forward to "CAT" discussions!
    20k Gunite/Prism Blue-Pebblesheen, Pentair Tagelus TA-100D Sand Filter, Heliocol Solar Water Heater, 2 bubblers and 2 waterfalls installed 2007, 3hp IntelliFlo VS Pump 011018 installed 2013, Aquabot Turbo T4 RC and Stenner 45MHP10 w/The Liquidator container installed 2012.
    Antigua Spa by Artesian Spas: 325 gl, 52 jets, 6 hp 2 sp & 6 hp 1 sp, Circulation System 24 Hour Whisper Pure, Ozonator, LED digital lighting, The Artesian Pillowfall installed 2007.
    Retired: 2hp Pentair Whisperflow, Legend Platinum w/booster pump, PH Adjuster
    Guest
    Welcome to our corner of the net!
    Apr 2008
    Rockville, MD
    7
    Thanks for the warm welcome!
    Ft Lauderdale, Florida
    1,455
    Andy,
    Welcome from a fellow industry person. These guys are a little strange, but they're good folks.
    You're well represented here. I've got your back!
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
