Thread: Trouble testing CYA
    Jun 2012
    Wynantskill, NY
    13
    Trouble testing CYA
    I am having a hard time testing my CYA level. It still appears as though it is at zero, although it is kind of subjective as to when the cloudy water obscures the black dot at the bottom of the small tube. I have been adding stablizer a little bit at a time, but want to be careful not to overshoot.
    I have this test kit:
    http://www.lesliespool.com/Home/Pool...its/81330.html
    Any suggestions? Am I doing this wrong or is there a better way to test your CYA level?
    13500 Gal AG - Hayward Sand Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,975
    Re: Trouble testing CYA
    That's the same test the TF100 uses, although I think the view tube is smaller.
    Unfortunately, that's pretty much the standard for CYA tests. I find it useful to take a reading, pour it back, mix again, and take another reading. Usually at least 3 out of 5 match, and that's the number I use.
    Jun 2012
    Wynantskill, NY
    13
    Ok, I will give that a try. When they say the black dot should disappear they mean that the water should be opaque enough that I don't see it at all right?
    wetchem's Avatar
    May 2012
    Somewhere in the middle of Nebraska
    208
    Go here
    extended-test-kit-directions-t25081.html
    scroll down to cya
    link there to site with examples.
    -wc
    Intex Ultraframe 14'x3.5-Round (4000ish-gal) AG - Vinyl - Intex 5667EG Sand Filter 1600gph :)
    ( retired: 637R Crtrge 1000gph someday it may have another life as a water fountain... or feet washer! Solar Water Heater? )
    :mrgreen: Click here to Goto Pool School. :scratch: How Much Of What? Click Here - Poolcalculator.com :lookhere: TestKits
    Jun 2012
    Wynantskill, NY
    13
    Great thanks a lot. That link to the Taylor photos Jason posted was very helpful.
    Jul 2011
    Monmouth County, New Jersey
    81
    That link was very helpful. I especially liked being able to see the bottom of the cya tube at the end of the test. Thanks for posting.
    Nancy Figur
    Built in October 2011, 16 x 26 x 20 L shaped vinyl IG steel wall pool, Hayward DE pro grid verticle filter 4800 pool, Hayward two speed superpump, 120,000 BTU Pentair Ultra Temp Heat Pump, Aqua Rite Salt system, 8' wide walk out steps, 2 skimmers, 4 returns, 2 main drains, 500 watt underwater light, intermatic mechanical timer
