Results 1 to 19 of 19
Thread: Main drain question
    Jun 2012
    Sydney, Nova Scotia, Canada
    74
    Main drain question
    how do I use just the main drain? the skimmer has 2 holes in it. is one the main drain? can i connect a u shaped tube to it to just suction from the main drain?
    Curtis
    Sydney Nova Scotia Canada
    Pool size: 26,500 gallons, Laser Sand filter 225(250lb), in ground, vinyl, hayward pump 1hp pump, Taylor Test Kit k-2006
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Main drain question
    Easier to just buy a diverter.
    There's a flapper on the bottom that slides that lets you regulate drain vs skimmer, so you can get both going at once.
    Mar 2008
    Lake Forest, CA
    114
    I have one of these diverters under my skimmer and I've never moved the flapper on it. It is partially covering the hole on the bottom of the diverter. I seem to remember reading that when covering the hole completely with the flapper, the suction is all main drain, and when the hole is completely uncovered the suction is all skimmer. Is this true?
    Greg
    12000 gal IG pool/spa combo,60 sq ft Jandy DEL filter,2 hp Jandy Stealth pump,Jandy LX400 400K BTU gas heater,Pentair Rainbow 300 off-line feeder (never gets used),Jandy Aqualink RS4 with PDA remote,3 Jandy 12" sheer descent waterfall features, Dolphin Oasis Z5 robotic cleaner
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by rhythm
    Greg
    Yes. But if the float inside stops floating for whatever reason, it goes all main drain.
    Feb 2012
    Memphis, TN
    52
    I have a skimmer that has 2 holes in it with no diverter. are diverters all the same and where can I get one locally?
    11,000 gal Fiberglass IG, Jacuzzi sand filter, Pentair Superflo 1.5hp 2speed pump, Hayward AQR15, Maytronics Active20, K-2006 kit, K1766, SpeedStir
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by nismostate
    I just measured the inside of the skimmer to get the diameter and went to the local pool store. Told the guy what I wanted, he picked one off the shelf, and that was that. I'm not even sure if they come in different sizes. It was only about ten bucks.
    38,359
    there is another design that looks like a Twinkie which is oval. Looking at the bottom of the skimmer you should be able to tell if you need the round UFO or the oval Twinkie.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Brand new to pools but my pool people told me there was little advantage to these and they easily break. So are they worth it?
    16,000 In Ground Kidney Plaster Pool, SWG, Sand Filter
    BobinBaltimore's Avatar
    Dec 2009
    Northeast of Baltimore, MD
    116
    We called them Turtles back in the day. The diverter on the bottom can break, but they are pretty tough and I recall them lasting for a couple of seasons. Our primary use for them was to avoid pulling from the skimmers when the water level was low or highly variable for some reason. When the level in the skimmer box is low, the float falls to seal off the skimmer intake (or at least mostly block it, reducing the flow). It was cheap insurance for that purpose.
    25' x 37' freeform, 22,000 gallon saltwater, 3'6" to 6'6" deep, including baja shelf and benches, 120 ft EP Henry retaining wall
    Pentair equipment (CC420 cartridge filter, VS-3050 variable speed pump, IC 60 salt cell, EasyTouch), 200 sq ft pool house
    View our Pool Build - View our Pool House Build
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by bchance1
    I like having it.
    It guarantees bottom circulation for starters. I also don't have the temperature stratification I've felt in many pools - it's the same at the top as at the bottom. If there's only a few pieces of debris on the bottom, I've gotten pretty good at brushing them towards the drain and away they go. No messing with the vacuum.
    38,359
    I have never had a diverter break ... Although I have only had them for about 5 years. I would think they would only get weak if you were putting tablets in the skimmer.
    Aug 2011
    Central Valley California
    121
    So to get half the suction from the main drain and half the suction from the skimmer, you have to have the bottom flapper on the diverter 1/2 open?
    23,000 gal IG Plaster 1989
    Purex Triton FNS Plus DE Filter Model FSNP 60
    1 Hp pump, Polaris 380 w/booster pump
    700 Gal Spa
    Laars Lite Heater T-F 100 Test Kit
    38,359
    that is the basic idea. Open it more to have more skimmer. I actually leave my flap open all the way to maximize skimming while running my pump on low speed ... based on the leaves on the bottom drain occasionally, I must still be getting a little suction through the bottom.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Little advantage to them? I don't know what that means, but you won't get any suction from the main drain without one.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    They simply said there was no advantage to having them over just leaving the skimmer as the main suction. So I guess the real question is do you NEED suction from the bottom drains? Also any suggestions where to pick one of these up online?
    Dec 2009
    116
    You absolutely want to have suction from the main drains, in combination with skimmers. Not only can it help level out the temperature (as someone mentioned above), but it ensures that water toward the bottom is pulled in and filtered, avoiding dead zones. Additionally, when you sweep the pool bottom, you can push toward the main drains and know that at least some of that "goodness" will make it right to the filter. Pools are intended to be thought of as a three-dimensional system. Pulling only from the skimmers can - depending on the location of your inlets - lead to circulating only the top couple feet of water. If the pool is being used often and the water chopped up, perhaps not a big deal. But for my pool, which is used primarily on weekends, I would hate to have the bottom third of water sitting there.
    That said, ever pool is different and tuning each system takes some plain old trial and error. You may not need or want to pull from the mains all the time, or at the same rate, depending on circumstances. But it can be a very helpful thing!
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by CUTiger78
    ? Can't you just have main and skimmer plumbed separately?
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by UnderWaterVanya
    Sure ya can. If they're plumbed together, though, you need a diverter gizmo to get suction from both. I probably wasn't clear in my first response.
    TF-100 test kit.
    Jun 2012
    Mint Hill, NC
    2,589
    It's my relative lack of knowledge more than your post that was the cause here I suspect.
    Thanks for the clarification - I just don't know enough to know if I know or if I only think I know on some of these questions.
