Thread: Ph and TA
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Ph and TA
    I finally got my ph in check, it has been high since the pool opening, it is around 7.5 now. My TA has always been about 110, but when I opened this year it was extremely low. I got it back up to 110. But now that my ph is where it needs to be, the TA has crept up to about 150, is this normal and OK, or do I need to lower it? And if I do, how do I do it? Thanks!
    FC 5
    CC 0
    Ph 7.5
    TA 150
    CYA 40 ish
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Ph and TA
    The TA is fine. Each time your pH hits 7.8, lower it to 7.2. Over time the TA will come down.
    If you start to become annoyed by having to lower the pH too often , then you can do the TA lowering process in Pool School: http://www.troublefreepool.com/pool-...l%20alkalinity
    You're done SLAMing when:
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Re: Ph and TA
    Thanks Butterfly! Yeah, I think I'll just let it ride and keep a better eye on the ph.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Ph and TA
    Quote Originally Posted by pepsiholic
