Thread: Exposed Aggregate Concrete Deck - covering solutions??
    Good afternoon everyone. My pool deck has exposed concrete aggregate and is extremely rough on our feet. Does anyone have any suggestions on the most economical way to cover, smooth, overlay, etc... the concrete. We plan on doing a major rehab next year, but just bounching this off the boards for any temporary, inexpensive solutions.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Exposed Aggregate Concrete Deck - covering solutions??
    Inexpensive isn't going to be easy. A heavy coat of sealer will help.
    Jun 2012
    Crystal Lake, IL
    35
    I have the same problem. My cheap solution is to wear flip flops and take them off right at the stairs so I have them when I get out.
    18,000 Gallons 16x32 In Ground Vinyl
    Purex Triton TR-60 Sand Filter * Pentair SuperFlo 1-1/2 HP (P/N 340039)
    MiniMax Gas Heater * Pentair Kreepy Krauly Legend
    Coverstar Automatic Cover * Built in 1993
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Inexpensive is the hard part here.
    Ike
    May 2012
    San Jose, CA
    141
    We just had ours torn up and will go back with travertine. I could figure out a cheap way either.
    Talked to contractors about going over the top with pavers and some said they would do it and others not. The aggregate began to lift some and that is when we decided to just remove it. Took us 14 years to finally make that decision. Good luck...
    24k gal 16x38, spa 7x6, Colorscape Caribbean Blue plaster, Pentair Intelliflow, Hayward jacuzzi air pump, Pentair 520 filter, Raypak 336k cu-ni heater, Aquabot Turbo T... pool remodel finished 8/2012.
