Thread: Lowering CYA
    Jun 2012
    Howard City, MI
    54
    Lowering CYA
    I just tested my CYA and it is currently 50. The pool calculator recommends draining 20% of pool water. How do I go about doing that? Can I just open plug and drain into yard?
    Above-Ground Pro Series 18'x48" Metal Frame - Approx 6,450 gallons
    Skimmer Filter System (cartridge): SFS1000 w/ F1500C Pump: 120watts/2.0amps/1500g.p.h
    Purchased & Installed: 6/7/12 (week of)
    Jun 2011
    Long Beach, CA
    2,778
    Re: Lowering CYA
    Your CYA of 50 is recommeded for most outdoor pools. Is there a reason you want to lower it?
    Jun 2012
    Howard City, MI
    54
    Re: Lowering CYA
    No, I just wasn't sure if I needed to or not. The CYA test can be a little tricky for someone with terrible eyes. At first I thought my reading (the black dot started to disappear from top view) was 80, but as I continued to add drops I realized my first reading may not be right.
    This is my least favorite test and hard for me to read.
    38,235
    Re: Lowering CYA
    Further info on the CYA test (and the others), if you have not seen it:
    extended-test-kit-directions-t25081.html#p206397
    Note that the lighting is quite important for the CYA test.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Lowering CYA
    If that's all you can find wrong with your water, leave it alone!
    http://tftestkits.net sells a standard solution for the CYA test. It is a known 50ppm solution that you use in place of pool water in the CYA test to check yourself. Then you can experiment with the lighting, how far to hold it, etc etc until you know what to do to get an accurate reading.
    Jun 2012
    Howard City, MI
    54
    Re: Lowering CYA
    Thank you to all for your help. couldn't do it without you.
