Thread: Jandy Automation Costs
    In the process of building a new inground pool and attached spa w/spillover. It will have all Jandy components (CV580 filter, AquaPure 1400 SWG, 2hp variable speed pump, Legacy 400k BTU heater, 2hp blower for spa, 3hp jet pump for spa). My question is what's needed to fully automate everything using the IAquaLink and my iPhone/PC as well as how much this should cost installed.
    Mike
    8 lane 25 meter 200,000 gallon outdoor pool (liquid chlorine)
    3 lane 25 yard 60,000 gallon indoor pool (liquid chlorine)
    3 Spa's 1200-600 gallon (trichlor/liquid chlorine)
    1 kids pool 40,000 gallon
    14x24 above ground SWG
    44,000 inground home pool (trichlor/liquid chrloine)
    AFO/CPO/LGIT/WSIT
    Southwest Utah Health Inspector/Pool Regulator
    Re: Jandy Automation Costs
    From what I've researched, I believe I need the following. Please let me know if these are good choices or if any components are missing/wrong.
    PDA-PS8 System
    PureLink sub panel power center w/ 12 breaker base
    AquaLink cell kit for pools up to 40k gallons
    All together, they are around $2400. What would be the avg cost to install?
    AFO/CPO/LGIT/WSIT
    Anyone have an idea on installation costs? Alternatively, is this something a DIYer can do?
    AFO/CPO/LGIT/WSIT
    Aug 2010
    Austin, TX
    200
    Assuming they have to run a sub-panel at the pump to wire up all of that equipment, there is not much more to do to install the controller. I would definitely have an electrician wire it up to code given the consequences if there is a short and not protected by a GFI circuit. Once the 110/240 is all done up, everything else is easily DIY if you fancy yourself a handy-type person.
    38K Gallons IG, Intelliflow VS-SVRS, 30GPM 24/7, 72sqft DE Filter, Spectralight UV, Jandy C1900 driving Liquid Chlorine and Acid (toys, I know..), Jandy LXi gas heater, Aquacal SQ175 Heatpump, Riverflow Competition swimmer, Jandy automation, Touch and iAqualink, Pebblesheen | The Build
