Thread: Above ground pool wiring setup
    Hello,
    I just installed a 18ft round above ground pool and currently working on my deck. I am very much a DIY guy and did 90% of the work so far myself (with the exception of the liner and water).
    I wired to a twist lock receptacle mounted to the ledger board of the house for the deck and do not have a timer installed yet. I wanted to know if anyone can post up pictures or explain how they wired their pumps/filters. I wanted to put a light switch on the underside of the deck where its easily accessible to turn the pump on and off for cleaning and maintenance. Did anyone do anything like this? The outlet is such a pain to crawl under the deck and reach to unplug, it would be much easier to just flip a switch. Yes, the switch would be in a weatherproof box.
    Also, while on the topic, any reccomendations on timers? This is my first pool and while the deck is still open, I would like to head off some of these issues now.
    Thanks!
    Jul 2009
    Olney, MD
    218
    Re: Above ground pool wiring setup
    If you want to put a timer in as well, why not just install a timer and use that to manually turn on/off the pump as well?
    Intermatic is the brand that is probably most popular. Take a look and find the right product for your needs.
    http://www.intermatic.com/en/Products/Pool_and_Spa.aspx
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
