Results 1 to 8 of 8
Thread: New Complete FAS-DPD chlorine K-2006 Test Kit
    Jun 2012
    Howard City, MI
    54
    I just received my new Taylor K-2006 Test Kit. Oh My!!!! Looks cool but right now my head is spinning just reading the instructions for testing my chlorine Previously I have only had the hth test kit that you just add drops and it figures chlorine.
    Somebody please help me!!!!!
    1) I don't understand: NOTE: For 1 drop = .2 ppm, use 25 mL sample. For 1 drop = 0.5 ppm, use 10 mL sample.
    2) So once I figure out #1 above, then I first test and get results for FC. Then I follow steps, test, and get results for CC. ....Don't I just have to record FC in the pool calculator? Is it necessary to follow addl steps to get number for CC?
    3) I haven't read past the Chlorine test, but I really hope it gets a little easier. I may be back with more questions.
    Just all seems a little overwhelming right now. Sorry if I seem quite ignorant and thanks so much for any help offered.
    Above-Ground Pro Series 18'x48" Metal Frame - Approx 6,450 gallons
    Skimmer Filter System (cartridge): SFS1000 w/ F1500C Pump: 120watts/2.0amps/1500g.p.h
    Purchased & Installed: 6/7/12 (week of)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: New Complete FAS-DPD chlorine K-2006 Test Kit
    If you fill the chlorine tube to 10ml, when you add the R-0871 each drop indicates 0.5 ppm FC. If you fill the tube to the 25ml mark, each drop represents 0.2ppm FC. Stick with the 10ml sample.
    Jun 2012
    Howard City, MI
    54
    Do I need to test for CC along with FC? The pool calculator only records the FC?
    SW Indiana
    9,199
    Quote Originally Posted by Terrjam
    If your water is clean and clear, probably not. If you have doubts, you can do the CC test after the FC test.
    38,301
    More detailed instructions for all the tests:
    extended-test-kit-directions-t25081.html
    Jun 2012
    Howard City, MI
    54
    As always, Thank You to all for your help and wonderful advice. It is much appreciated.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello,
    You tube is your friend:
    http://www.youtube.com/results?search_q ... -2006+test
    Chlorine test: http://www.youtube.com/watch?v=oa8iq8htR-s
    Ph test: http://www.youtube.com/watch?v=aNlqCsLYqkY
    The first link shows the different videos available.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If I am doing the FAS-DPD chlorine test anyways, I always also do the CC test since it usually reads <0.5 ppm, but if it doesn't , I want to know. It takes very little time and reagent.
