Thread: Daily Chlorine Test Kit, Which One?
    Jun 2012
    Broken Arrow, OK, USA
    50
    So the TF-100 comes with the Taylor K-1000 Chlorine/pH kit for daily testing, which is the OT method. For about the same price, the K-1001 kit does the same test (although, I guess it's FC, instead of TC), using the DPD method. Which would be better to get, considering I will already have the FAS/DPD comprehensive test when needed?
    1,720 Gallon Intex 12' x 30" Metal Frame AGP w/ 1-1/2" Retrofit Intake/Exhaust | Intex SWCG w/ 2,800 GPH Sand Filter Pump controlled with Aube TI062/U Timer
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Daily Chlorine Test Kit, Which One?
    The OTO test (T-1000) is always able to detect the presence of chlorine, the DPD bleaches out above 10 ppm. I would use the OTO or FAS-DPD (not DPD) for daily measurements.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    An OTO test in fine for everyday testing when you need to just detect the presence of chlorine, or less than 5 ppm. Use FAS/DPD test for higher and more accurate testing, as well as OCLT when needed.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Jun 2012
    50
    Thanks, guys, I'll just go with the OTO test then. Seems easier to do as well.
