Thread: brown spot on bottom of pool w/pics
    Hello, potential first time pool owner here
    A pool at the house I'm looking at has a few brown spots at the deep end of the pool near the bottom. The biggest is about baseball size. Goggling mostly points to rebar rust, and I just learnt it might just be a surface stain "dirt scale"?...
    I took some photos so what to get some expert opinion here:
    If it is rebar rusting thru..how much am I looking at?
    If it is just surface stain, what do i use to get rid of it? Thanks in advance!
    zoomed in
    another spot
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: brown spot on bottom of pool w/pics
    It's hard to tell just by looking what type of stain it is. That last picture looks like it has a raised edge. Some stains can be taken care of with raised chlorine levels and brushing, but the stain will need to be tested to find the cause and figure out a solution.
    If you can find out some of the pool's maintainence history and current test results that would help.
    Love TFP? Become a
    TFP Supporter!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    If it is just a surface stain, a vitamin C tablet will remove it.
