Thread: Stain Removal Question
    I have a few brown stains in my pool. They look like comets or something. They are 4 to 6 inches across and taper down to nothing and are about a foot long. A friend looked at them and said that he had similar stains and he hired a man who put pvc pipe into the pool over the stains and then poured muriatic acid down the pipe and that it removed the stains on the bottom of his pool. Does this make sense?
    Many Thanks,
    Russ Stevenson
    10k in ground plaster
    Build date around 1980
    1.0 HP pump, Baker Hydropak Skimmer
    wetchem's Avatar
    May 2012
    Somewhere in the middle of Nebraska
    208
    Re: Stain Removal Question
    Do a search on citric acid on this site.
    Sounds like iron staining.
    As for pouring straight muratic acid on the walls... that will work... and it may damage the walls and anything else it touches...
    -wc
    Intex Ultraframe 14'x3.5-Round (4000ish-gal) AG - Vinyl - Intex 5667EG Sand Filter 1600gph :)
    ( retired: 637R Crtrge 1000gph someday it may have another life as a water fountain... or feet washer! Solar Water Heater? )
    :mrgreen: Click here to Goto Pool School. :scratch: How Much Of What? Click Here - Poolcalculator.com :lookhere: TestKits
    Thanks!
    Many Thanks,
    Russ Stevenson
