Results 1 to 7 of 7
Thread: Vinyl inground - should I be brushing - slippery sometimes
    Jul 2011
    Monmouth County, New Jersey
    81
    Hi,
    I hear people talking about brushing the walls and floor of their pools. Is that just for concrete pools or should vinyl pool owners be doing that too. I do it sometimes to brush the dust/dirt towards the main drains which really works well.
    Sometimes, when we first get in the pool the floor is a little bit slippery and the slope to the deeper end is slippery. Once everyone has walked around on the floor it immediately gets not slippery at all.
    Slippery to me always meant algae but my chlorine is much higher than needed and I have no ccs and everything else is pretty much where it should be. We also have salt - maybe that is it. The water is crystal clear and sparkles.
    Is anyone else's pool slippery when you first get in? The pool is pretty much brand new so I have nothing to compare it to.
    Nancy
    Built in October 2011, 16 x 26 x 20 L shaped vinyl IG steel wall pool, Hayward DE pro grid verticle filter 4800 pool, Hayward two speed superpump, 120,000 BTU Pentair Ultra Temp Heat Pump, Aqua Rite Salt system, 8' wide walk out steps, 2 skimmers, 4 returns, 2 main drains, 500 watt underwater light, intermatic mechanical timer
    22,548
    Re: Vinyl inground - should I be brushing - slippery sometim
    Yes you should be brushing it regularly. It may not be quite as important as a plaster pool but it's still important.
    Jun 2012
    Louisville, KY
    266
    See my sig. I brush at least once a week just to get stuff suspended into the water and go through the filter.
    Make sure you get a brush for vinyl lined pools. You're not scrubbing it with hard pressure. Just brushing it to suspend stuff into the water for your filter to handle.
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Bama maybe you can elaborate on what exactly one would be brushing off in a properly maintained vinyl pools sides. I've been occasionally rubbing my hand along the water line to dislodge dirt and dead bugs but I've not seen anything under the water line....nor on the bottom that requires a brush.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    22,548
    Oils and other stuff can get stuck to the liner and brushing it loosens it from the liner. The OP mentioned slippery liner. Brushing would help that.
    Jul 2008
    Seacoast, NH
    250
    My steps were wicked slippery the first summer after the install too.
    I try to brush once a week, but maybe not as good about that as I should be.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    Jul 2011
    81
    I will try brushing every day and see if that makes a difference.
    Our salt levels were low for a while - not so low that the swg wasn't working but not near the recommended target of 3200. I have added enough salt recently to get it from 2800 to 3200. I wonder could that be the difference in the feel of the liner. We did notice that the water seemed silky but maybe it changes the way the liner feels.
    After walking around on it and swimming for a bit it goes away and it isn't algae but I would love to know why it is slippery.
