Results 1 to 15 of 15
Thread: Finished
    Jun 2011
    Michigan
    41
    Finished
    I finally finished my pool project, I buried a Radiant Metric GT pool. Thanks for all the help from forum members.
    24' x 52" round Radiant Metric GT, Fully Buried.
    38,475
    Re: Finished
    Looks really nice
    Too bad there is such a gap between the large step pavers. I can not think of an easy way to change it though ... might be kind of an ankle hazard after a few beverages at night.
    Jun 2011
    Michigan
    41
    Re: Finished
    Of course you noticed the one last thing on my to do list , I have been searching around on how to fill those gaps, and there is something called gator dust, basically a mixture of gravel and polymeric sand.
    22,553
    Re: Finished
    I would cut them all to fit and add a small piece in the center to make up the difference.
    Casey's Avatar
    SW PA
    10,457
    Re: Finished
    Wow! That is awesome!
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Finished
    Times 2. You can rent a concrete handheld gas saw at HD or lowes etc. that will cut them.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Jun 2011
    Michigan
    41
    Re: Finished
    Thanks for the info, they were pretty thick, so I wasn't sure if I could cut them. The gap actually looks larger in the picture, it is not even 2" at the widest point, but if I get motivated I will probably try and do something with them.
    Here are a couple more pics of my poor mans inground pool.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Finished
    That is a great looking pool
    Samantha Sabrina's Avatar
    Apr 2012
    Bloomsdale, Mo
    346
    Re: Finished
    That is one Impressive looking setup you have there!
    Job Well Done!
    As for the spaces between the bricks, I would look into soemthing like grout to fill them, you should be able to find something in a color that would accent what you have done already, kill 2 birds with one stone.
    Personally I wouldn't dig them all out and start over.
    Here's to many Happy hours of enjoyment in your new Oasis!
    Samantha
    In the process of building for a 22' Intex Ultra Frame, (completion date up in the air at this point).
    We could not beat our backyard into submission so we "Buried It".
    Guest
    Re: Finished
    Awesome job on the pool........looks Great !
    Re: Finished
    The stones around the back look nice. That was a good idea to manage the grade a bit.
    Shelley
    Denver, CO
    Re: Finished
    Pool looks great!! We also have a round Radiant and I'm currently trying to figure out what sort of deck to put up around it. I like how you used the pavers at the lip of the pool. Was there reasoning behind that or was it purely aesthetic?
    Also, did you paint the concrete with anything?
    Thanks!
    Vette, DH, & 2 DDs Our IG AGP Build
    In-ground Radiant 24', 1.5 Pentair IntelliFlo pump, Hayward Sand Filter
    Mar 2013
    New Hampshire
    351
    Re: Finished
    Talk about no privacy.....
    18k: IG: Black Granite Liner: Aspen: 16x33.5: SWG: Polaris 280
    My pool build new-pool-build-in-nh-t60957.html
    Re: Finished
    How do you like the pebbles around the pool? We are considering doing that to a portion.
    CCisotope's Avatar
    Aug 2013
    Cypress, TX
    136
    Re: Finished
    Your pool looks awesome! Great job!
    IG Gunite 30k gallons, custom WetEdge finish with glass beads, spa, Pentair 520sq. ft. Cartridge Filter, Pentair 3HP intelliflow V.S pump, Pentair 400K BTU Heater Master Temp, Pentair 2HP Whisperflo- Model WF-28, Silencer Air Blower 1.5 HP, Pentair Boost Rite Universal Booster Pump, Rainbow 320, Easy Touch 8, My pool build:http://www.troublefreepool.com/threa...ypress-TX-Pics
