Thread: Upsizing Cartridge Filter
    Ohio
    87
    I currently have a 75 sq ft cartridge filter (Jacuzzi CFR75) that works fine. I am debating on convertng it to be a 150 sq ft model after reading some of the post on here and pool forum. I currently cycle two cartridges and one is due to be replaced so the cost to changeover would not be that much extra. I will need to purchase the larger dirtcatcher that the filter sits on as the only additional piece. All other components of the filter are the same.
    I know that the major pro will be doubling the sq ft of my filter material but are there any cons to this I am not seeing?
    A link to the filter is Filter Components
    Thanks to all
    24'x54" Sharkline Matrix by Wilbar International, 15,200 gallons (2015)
    Jacuzzi 75 sq ft Cartridge Filter 1 hp two speed pump
    Solar Heat with Goldline GL-235 Controller
    Intex Krystal Clear Model 28669 SWG
    TF100, SampleSizer, and Speed Stir
    30,432
    Other than what you already know (cost, effort, etc.), I can think of no downside to increasing filter capacity. Essentially, everything will improve.
    Arizona
    924
    I think you are smart to upsize.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    mas985's Avatar
    Pleasanton, CA
    11,743
    I have a 420 sqft cartridge and I am glad I did. After a year without cleaning it, I have no PSI rise. I could probably go two years but once a year is not that bad. I would go as large as your budget permits.
    Mark
    Mar 2007
    San Rafael, CA USA
    12,082
    Ditto for me. My cartridge filter is over-sized (it's a 4 cartridge unit) and I only clean it once a year with no pressure rise. It makes maintenance SO much easier and I'm so glad my pool builder did this (I didn't know anything about pools when we had one put in).
