Thread: Dumb Question, How To Hook Up the Vacuum?
    Jul 2007
    Hillsborough, NC
    525
    We have had storms the last 2 nights and my pool really needs vacuuming. I have a Hayward widemouth filter. I have an attachment that looks to be for the vac hose - the hose attaches at a right-angle. I assumed you just slid it through the filter opening and put it down on top of the basket, but it doesn't fit through the opening. If I bring it over the top of the pool wall, a) air gets in and I don't want that and b) the hose can't bend up to to go over the wall. Is there something I am missing?
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Re: Dumb Question, How To Hook Up the Vacuum?
    You can put the plate on from the top and run the hose in through the skimmer mouth and connect them together inside the skimmer.
    Jul 2007
    Hillsborough, NC
    525
    Ok. that seems a lot of work and not a very good design each time I want to vacuum. I guess I need to get a tooless hose clamp. I also found a site that suggests one of these:
    The vacuum hose should be a friction fit into the vacuum plate, very easy to attach.
    Jul 2007
    Hillsborough, NC
    525
    Oh. I didn't know that. I guess if it leaks a little it doesn't really matter. I will take off the hose clamp I put on it then.
