Results 1 to 14 of 14
Thread: I don't know how to work a vacuum :(
    Jun 2012
    Indiana
    81
    Yes, I'm that much of a newbie why doesn't all my new equipment come with directions?! My skimmer has an extra lid with a spout, so my assumption is that I hook the hose up to that guy. I have read through various posts that the hose needs filled with water. Assuming I have these points correct and there is nothing more to the assembly or anything, the part I am stuck on is on which setting do I put the valve on my sand filter? It is the multi-valve variety. I assume I can put it on the "Bypass to Waste" setting, but that means all my precious new water i just paid $350 for gets dumped in the yard, right? Besides, I am not sure I have everything I need in order to attach the backwash hose. If it makes a difference, what I need to vacuum is the sand the installers got on the filter. There also may be leaves down there too. Also, i have an automatic cleaner I would like to try using first before manually doing it, if that changes things. We can't get in it yet, and I have no deck yet. I'm 5 ft tall with 54" walls, so the manual beast seems impossible right now. My pump only has one speed, so there is no question there. Thanks, TFP!
    Jess :) from southeastern Indiana, USA
    27' x 54" ~17,600gal AG round
    Waterway Ecco 22", 250# oval sand filter 2.6 SF, 55 GPM
    1.5 hp 1-speed pump
    pool DOB July 2012
    Re: I don't know how to work a vacuum :(
    You have the vacuum plate and fill with water first part right
    Normal vacuuming should be done with the valve set to filter. Every now and then there are reasons to vacuum to waste, but they are rare and not worth talking about right now.
    topher's Avatar
    Jun 2012
    toronto, Ontario, Canada
    136
    I would get the leaves out with a net, and then vacuum on filter.
    13500 gallon AG, build late 90's, Hayward S220T sand filter,1Hp aqua coastal
    Gasser BBQ broilmate 155154 LP, Smoker CGK (akorn)
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    My hose has two similar but ultimately different ends. On end is fixed, the other end can rotate....the end piece will spin on the end of the hose. If you put the end that rotates in the skimmer it will suck in air and you'll never get it to work, the swivel/rotate end goes on the vacuum head....
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Jun 2012
    Indiana
    81
    Thanks all! I have it going!! I did try to fish out all that I could tell was leaves with the net, but any still down there will be caught in the filter basket, if that barracuda can get 'em.
    Also, I hope it wasn't too confusing when I called the liner the filter. I'm going to blame it on this heat LOL we are lingering around the triple digit mark!
    Southeastern Indiana, USA
    27' x 4' 17,600gal AG round
    1.5 HP 1 speed pump
    22" Ecco sand filter
    1.5 hp 1-speed pump
    pool DOB July 2012
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Quote Originally Posted by iSmile
    I watched a BUNCH of YouTube videos on pool school stuff (noting variations in procedures and equipment) which I found very useful.
    http://www.youtube.com/watch?v=09sVvEKKHvY
    Jun 2012
    Indiana
    81
    Yesterday was my first try at the manual vacuum. I actually just climbed in the pool and vacuumed. Thankfully. My hose would not stay attached to the vacuum head. The only way I could finish the job was to physically hold the hose down. Even then, I probably reattached the thing a dozen times. I wondered if this is common and if one of you had a trick for keeping it on, or if there is something I'm simply doing wrong. Thanks once again!
    1.5 HP 1 speed pump
    1.5 hp 1-speed pump
    pool DOB July 2012
    22,553
    Post a pic of the vacuum and hose.
    Mine will pop off once in a while but it's because the cuff is split. They normally stay on really well.
    Jun 2012
    Indiana
    81
    Good gravy, my guess is my hose, new out of the box yesterday, was delivered to me busted That is an easy enough fix.
    1.5 hp 1-speed pump
    pool DOB July 2012
    22,553
    Bummer!
    May 2011
    Clearwater, FL.
    446
    Hi iSmile,
    I use 2 of these for my vacuum hose:
    http://www.homedepot.com/h_d1/N-25ecodZ ... reId=10051
    Connect one to the hose end to go on the skimmer cap/lid/plate whatever you want to call it.
    Push it on and use 2 zip ties the hold it on tight just on the hose side so when you push it on the plate the rubber hose helps with holding it on and gives help in sealing.
    I did the same thing for the hose end to the vacuum head, use 2 zip ties on the vacuum head body so it on tight, and then push in the clip end that snaps in the nipple until it clips in. Don't zip tie hose end so you can turn it to keep the hose from binding, this just keeps it from popping off.
    I just let the leaves collect in the skimmer basket, if a ton of leaves... you might need to stop and clean basket through the vacuuming job.
    I'll try to remember to take a couple of pic's of this, but pretty simple trick.
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Jun 2012
    Indiana
    81
    Hey chuck, I thought I'd remind you about that offer to take pix next time you vacuum. I'm a visual learner and unable to wrap my noob brain around the parts and pieces. Even my new non-busted hose pops off the vacuum head constantly, so I'm banking on your little trick!
    1.5 hp 1-speed pump
    pool DOB July 2012
    Jul 2010
    Philly
    332
    Sent from my iPhone
    I have what looks like the same hose in your picture. Those cuffs should screw back on. I just make sure they're tight before vacuuming. Mine screw back on backwards. By backwards I mean they are reverse threaded (left handed) and tighten up the opposite way you would normally turn a normal fitting. Maybe I'm reading this wrong. Is your fitting threaded?
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Hayward S166T 100 lb sand filter
    Jun 2012
    Indiana
    81
    I had tried re-threading it, without success, back when I discovered it, but since it was new, the pool store replaced it anyway. I assumed that the new hose would solve the problem, but the thing just hops off the vacuum and wants to float around the pool. Luckily manual vacuuming isn't a job I've attempted but 3 times all summer. Highly frustrating!
    1.5 hp 1-speed pump
    pool DOB July 2012
