Thread: How to clean Buildup under spa
    Dallas, TX
    227
    See pictures. Have large buildups under the hottub Rick overflow and along the grout lines on tiles in a few spots near the hot tub. I think I remember MA/water mix in a cup with some sort or brush to clean it.
    [attachment=1:ie0qxdz3]ImageUploadedByTapatalk1341171044.801445.jpg[/attachment:ie0qxdz3]
    [attachment=0:ie0qxdz3]ImageUploadedByTapatalk1341171059.090569.jpg[/attachment:ie0qxdz3]
    new house: TBDK gal IG plaster pool, filter Titan CM DE filter 36 sq ft , 1.5 HP Pump; Polaris 380
    Dallas, TX
    227
    Re: How to clean Buildup under spa
    Found it! it was 5-1 or 3-1 water to acid ratio. Worked pretty well on the big areas after applying for a while and scrubbing.
