Thread: Skimmer Socks
    Jun 2012
    Lafayette, Ca / USA
    260
    Skimmer Socks
    I read here about those Skimmer Socks that are added to the skimmer basket. Couple of questions:
    - Do they affect the flow rate of the filter system? e.g., reduce the sucking & return pressure of the pump & filter?
    - The images I've seen show them attached to the UNDERSIDE of the filter basket - the direction into the return system. Is there ever any concern about the sock being sucked off the basket and into the filter system?
    - Do you leave yours on all the time, or maybe just after a lot of pool bathing parties?
    Thanks in advance
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
    Jul 2012
    North Atlanta
    22
    Re: Skimmer Socks
    Hello
    I just registered today However I've learned alot of good stuff on here
    I just bought a skimmer sock the last week. I have a 18x36 inground with a sand filter
    The reason for me getting this was it collects alot of lil stuff (Dog hair, bugs lil pieces of **** and whatever)
    I bought a pack at a local pool store like 5 for $8
    I don't notice any filter suction loss but I do keep an eye out for leaves as they can clog it up alot quicker.
    So far so good on the filter sock
    18x36 ig Vinyl 26000 gal
    30 Jandy Sand Filter
    2hp Pentair Challenger
    Hayward Chlorinator
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Skimmer Socks
    The skimmer basket socks go inside the basket! Otherwise, as you said, there would be a concern it would end up in the filter system!
    I leave the socks in the basket as long as the pump/filter are running. Since we never run our pump at night, the socks get pulled and rinsed, not allowed to sit in basket overnight.
    You're done SLAMing when:
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    651
    Re: Skimmer Socks
    I leave my skimmer sock (inside the basket) in 7X24, and change it weekly. I just throw the dirty one in the wash after rinsing it.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Re: Skimmer Socks
    I keep the skimmer sock in place until it starts to shred. I even keep it on when we vacuum the pool, but had to add a large rubber band to keep it in place with the heavy suction. I buy them online in multi packs, and get several packs at a time.
