Results 1 to 17 of 17
Thread: OCLT ? What is that Test ?
    Jun 2012
    Lafayette, Ca / USA
    260
    I see this referenced from time to time in many posts and can't figure out what this test is ... It's not documented in the Abbreviations link ..
    What is it? Thanks
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: OCLT ? What is that Test ?
    Test right at dark and again right at first light or before to see if anything besides swimmers or sunshine is eatin' your chlorine...............i.e. algae.
    Overnight chlorine loss test
    Jun 2012
    Lafayette, Ca / USA
    260
    Thanks !! Will do ..
    Overnight Chlorine Loss Test -- bring pool up to a certain FC after dark, test again to be sure of true level after circulating well, then retest before sun hits the pool. If FC has dropped overnight, you must still have organics in the pool. Must not run SWG during this test.
    Jun 2012
    Lafayette, Ca / USA
    260
    Oh, and PS -- I'm only testing FC ? or TC & CC ? Anything else?
    Jun 2012
    Lafayette, Ca / USA
    260
    In additon to that previous question above, is ANY drop normal?? e.g., What if my FC is say 7.4 at dusk -- what would a "normal" drop be - or should it be 7.4 in the morning ?
    Apr 2010
    East Texas
    9,655
    pool-school/shocking_your_pool
    Your answer is there.........................
    Jul 2010
    Philly
    332
    Quote Originally Posted by cody21
    You're testing FC and CC. Those two added together give you your TC number. The OCLT test is passed when you have a loss of 1ppm or less of FC and a CC reading of .5 or less. The third criteria is crystal clear water.
    Here's what I do when my water is clear but I suspect something is off. I add Chlorine to the upper part of my guidelines for my CYA. Mine is 4 to 6ppm for a CYA of 50. With the filter running I add my Chlorine when the sun dips below the trees and is completely off the pool. I test my FC level one to two hours later. I like to give the Chlorine a chance to sanitize anything introduced by swimming that day. Next day I check before the sun hits the pool.
    If my night time test is 5ppm FC and my morning test is 4ppm or more, I passed the FC part. If my CC test is .5 or less, I passed the CC part. If my water is still crystal clear, that's a passing grade.
    All my tests are done using the 10 ml sample size. There's no need to use the 25 ml size unless you like doing so. The 10 ml sample is precise enough and save on testing agents.
    If your water's not clear and you are shocking, there's no reason to perform the OCLT until your water is clear
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Hayward S166T 100 lb sand filter
    Jun 2012
    Lafayette, Ca / USA
    260
    Thanks so much .. makes perfect sense ...
    Not trying to revive an old thread but I have a follow up question and still have not figured out how to post a new question - could be my out of date web browser.
    Anyway, for the OCLT, do I do this with the pump on or off? I was told a long time ago to run the pump at night. Can't recall the reason, but the pump timer is set to kick on about 10:00 p.m. and the spa overflows into the pool making a very pleasant and relaxing sound right outside my bedroom (perhaps that was the reason). So for an OCLT, do I need to adjust my pump schedule or not?
    14K IG plaster, 48SF DE (Pentair), 1/2 hp challenger, built in 1982, TF100 w/Speed Stir, Polaris 280 + 800 gal IG plaster spa with 1hp pump & 1/2hp blower
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I believe most are in the process of completing a "SLAM" when they do the OCLT, so their pump would be running all night. (It's best to run it 24/7 during the SLAM process.) You'll need to run the pump, for sure, for at least a half hour when you add your chlorine at night to make sure of your starting FC, and at least a half hour in the A.M. to make sure the water is well mixed. If your pump runs all night, you're good to go, just be sure to retest the morning value before the sun hits it.
    Thanks. I added chlorine and some acid around 4 hours ago. I just tested again. CL is >5ppm (very yellow, as in cab yellow) and FC was 4.5 (9 drops of reagent) with CC (chlorimines???) at 0.5 and PH is a solid 7.5 right now.
    Checked first thing this morning. Sun had been up for 20 minutes before me but the only shade my pool sees is early morning (pool in back yard and house faces slightly south of east so no direct sunlight for at least another hour). CL is still >5ppm and FC is still 4.5ppm, CC is 0.5 so no change at all in 8 hours.
    (1) if pool passes the OCLT that means do NOT slam?
    (2) with my numbers, is SLAMing going to do anything other than waste chlorine? (i.e. is there any preventative benefit to a SLAM)
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Not sure if you can get an accurate OCLT with the OTO test kit, more precise accuracy is needed.
    Aug 2016
    Rochester, NY
    53
    Looks like you performed both OTO and Fas-DPD tests. No need to perform both. fas-DPD is the preferred test.
    With no loss in FC and CC of 0.5 you are good to go, assuming water is clear. SLAM at this point would do nothing except use more of your chlorine supply.
    13.5K gallon vinyl 24' AG, 1 HP AquaTools AT2410130 pump, AquaTools AT3118 18" Sand Filter and Taylor K2006 test kit
    Thanks RK. I suspected as much but it is good to verify. My water is absolutely crystal clear. You can toss a dime in the pool and tell if it landed heads or tails up.
    I did perform both CL test. Why does the TF-100 ship with an OTO kit? I have been trying to figure that out since the FAS-DPD is so much more accurate and reading the posts on this forum it appears many if not most pool owners are running CL well above the OTO test limits. I have enough trouble distinguishing between the colors up to 5 but anything over 5ppm in the OTO kit is just dark yellow. Do most members just dump the OTO kit and do the FAS-DPD daily or do you just test weekly or do you keep some distilled water around and mix 50/50 to get a gauge using the OTO?
    So far I am happy with the new diet of liquid chlorine, I have gotten into a routine of come home, grab a sample and add chlorine before going inside. I am sure over time I will figure out how much to add daily and not worry too much about it. Honestly, the biggest benefit I see to liquid chlorine is that I actually check and put it in. Using tabs, it was so easy to fill the floater and go about my business until I just happened to think about it or looked outside and notice it was floating high in the water, so my CL was probably bouncing like ball.
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    891
    The OTO gives a quick and rough -'yep everything looks pretty good' sort of idea. The FAS-DPD gives the precision and your right -many just use the FAS-DPD test.
    As to how often to test its a personal preference and depends on the season but when you are just starting out it's a good idea to test more often to learn how your pool 'behaves'.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
