Liquidator allowing air in when pump is off
Yoav
64
Pardes Hanna, Israel
Hi All,
I have been using the LQ (with the 3/8) for a year now and love it.
That said, I have been ignoring an issue with it and would appreciate your help fixing it.
Since my LQ is higher than my IG pool, when the pump turns off water flows slowly from the LQ into the pool (via the outlet), until the OUT float cuts it off.
The problem, is that despite the check valve on the IN line, water returns to the pool on that line as well.
Naturally, once the water in the tank reaches the port's level, air gets sucked into the system (which means that my filter always has air in it, and that sucks!)
I thought maybe the valve was failing but the original 1/4 valve displays the same problem (it was unused before I tested it so there would be no blockage in it).
The only reason I could come up with for this, is that there is a minimal amount of water (i.e back pressure) that is required for the check valve to work, and that by the time the OUT float cuts of the flow of water out of the LQ, not enough water remains in the tank to allow the IN check valve to work.
(this also implies that the LQ is not designed to handle my pool setup properly which IMO is not very likely)
Does this make any sense? Any ideas on how to resolve this?
A few more things worth mentioning:
- There are times when it actually works and does not allow backflow (unfortunately, these are the exception)
- When the flow valve is closed (i.e no OUT flow), the water rises to the maximum in the tank, and no backflow or air returns to the system when the pump shuts off.
- I can't seem to remember if this has been going on from the moment I installed it, or if it had started later on.
Yoav.
