Thread: Pool Pilot Dig-220 Tri-sensor faulty temperature reading
    I have a 6 year old system and the temperature reading is 28 F when the actual is about 90 F. I have inspected the tri-sensor and am looking for advice on how to test to see if the tri-sensor is bad or the circuit board. Thanks Thomas
    22,537
    Re: Pool Pilot Dig-220 Tri-sensor faulty temperature reading
    Can't help you with the testing but if that's the only thing wrong, it's most likely the tri-sensor.
    Ft Lauderdale, Florida
    1,455
    Here you go.
    Attached Files Attached Files
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
