Thread: BBB for my hot tub,too?
    Apr 2009
    South Texas
    177
    I'm making my new pool a BBB pool. I'm wondering if I can do the same with my hot tub. It currently has bromine in it along with other pool store chemicals. Sure would be great if I could use the same stuff on both.
    Thanks!
    Just bought a new house in the country, no pool yet. :(
    Hot tub..500 gals..bromine
    TF100 test kit and speedstir
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: BBB for my hot tub,too?
    I do but be aware it's twice the testing!
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Mar 2007
    San Rafael, CA USA
    12,082
    As you'll see from the chlorine post for spas that Jason linked to, there are some differences than using chlorine in a pool. The bather load is much higher since the water volume is so low in a spa and they are typically covered so most of the chlorine loss comes from bather load, not from loss from sunlight. The other big difference is the amount of aeration in the spa, especially if you use jets. Getting the TA lower (to 50 ppm, if needed) and using 50 ppm Borates in the spa are important, even though the procedure says that the borates are optional, I'd say they are normally required to keep pH from climbing too high too fast even with the lower TA level.
