Become a TFP Supporter Pool School
Results 1 to 7 of 7
Thread: Intex 8110 Won't Turn On Anymore
    Worked fine for 2 yrs and 1 month so far this year.
    Had it on a daily 1 hr cycle. Worked like a charm but now it won't even turn on. No LED. Tried different power receptacles.
    I just unhooked it from the pool to try and troubleshoot, but not sure where to start.
    Would the LED even turn on if it didn't have water flow - how do I test the LED without hooking it back up?
    Would a dirty cell cause this? Maybe I will try to clean the cells.
    Re: Intex 8110 Won't Turn On Anymore
    Mine is doing the same thing.
    I am waiting on my dad to come
    home from vacation. He can usually
    fix anything. Hope you find answers too
    20 x 48 Intex Ultra Frame
    Sand filter with SWG attached.
    Deck added on (05/18/2013)
    Thinking about adding more deck
    Pool steps added in - (got rid of that crappy ladder that came with Intex pool) 05/18/2013.
    "A little bit of paradise in our yard"
    I ended up buying a new one. Let me know if you get your fixed. I kept the bad one.
    Good luck.
    Dad is a genius when it comes to parts - machines -0 etc -
    I am praying that he can fix it..
    I turned it off and I
    just keep checking the levels & taking good care of the poo
    Was your dad able to fix it? Had mine for 2 years and now all the sudden won't come on. Hoping it's a simple fix!
    Inground plaster. More information will be updated as I find the approximate numbers.
    Nope. Ended up buying my sisters old one.
    Hi All, its 2016 and I had the same 2 year issue that was described here; regarding no power to the GFCI module and unit. The answer is in the GFCI module. The module is between the chlorinator and the power receptacle. The connection blocks (in and out), are at the top and bottom of the module, with caps that are screwed in with 4 phillips screws, each. inside are 3 head, screw blocks; where the (black green white) wires connect.
    In troubleshooting, I carefully plugged it in with the caps off and metered the wires, and thankfully the switch was set to on, because just the pressure from the probes was enough to restore the connection. I tightened each of the connections, and it is chlorinating.
    Here's hoping this helps someone in 2020 or sooner.
