Thread: T/A (Total alkalinity) level & CH
    jgjh151's Avatar
    May 2012
    Glenville, NY
    39
    TA is reading 160, can we swim in this today or should I lower it first? Is the CH of 250 something to worry about before swimming as well?
    PH was a little high last night so I added pHDown..maybe that raised the TA?
    Latest readings:
    FC: 7.5
    CC: 0
    pH: 7.5
    T/A: 160
    CH: 250
    CYA: 55
    Temp: 84
    Jon
    21,000 gallons, Hayward sand filter, IG, 16x32 kidney, Vinyl, Hayward Super Pump 1hp, Flow rate: ?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: T/A (Total alkalinity) level & CH
    Go swimming!
    CH at 250 is just fine for any kind of pool. TA at 160 is a little high, but can be ignored unless CH is 500+ or your PH is going up annoyingly quickly.
    jgjh151's Avatar
    May 2012
    Glenville, NY
    39
    Great! Thanks for the input.
    Jon
