Thread: So jack's pink stuff lowers ph and eats ch too?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,765
    Inquiring minds would like to know
    I normally consume about 2ppm per day chlorine, with a ph drift upwards from 7.2 to 7.8 over a week to 10 days.
    I added 64 oz of jack's pink stuff b/c my iron staining was back and I'd only used maint levels before, assuming pool guys sequestrate added at start was still working.
    This a.m. My ph dropped from 7.6 to 7.4 and I used 3 ppm of chlorine.
    Is that the work of Jack? Just curious. I recall reading it is phosphoric acid, so perhaps I should not be surprised that it behave like, well, an acid!
    Someday I will master this predictive pool chem phenom
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Re: So jack's pink stuff lowers ph and eats ch too?
    Jack's, like nearly all sequestrants, is mildly acidic. Different brands vary in how much chlorine they consume. Jack's has one of the lowest chlorine consumptions, some other brands will use rather more chlorine.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,765
    Good to know - I'll target a wee bit higher when I add it!
    Thanks!
    Helpful Links:
