Results 1 to 7 of 7
Thread: Robertshaw 700-511 Millivolt gas valve help!
    MJCP's Avatar
    Sep 2007
    Michigan
    129
    I have the 700-511 gas valve which is the Universal replacement for my Teledyne Laars Series 2 Heater.
    The valve looks exactly the same as the old valve and connects exactly the same, specs the same, etc.....
    Only one problem there is an extra gas outlet, with a 1/4" brass connector, that does not appear on any of the drawings.
    When the valve is connected it behaves like the pilot (pushing the control down in the pilot position allows gas to flow through this outlet).
    There is already a pilot connection on the front.
    Can I simply plug this unneeded port? What is it supposed to be used for? and finally - Why is it not mentioned or shown in any of the instructions ?
    Thanks
    15x32 Lazy L Inground / Concrete - 20,000 US Gal 1979 build
    1.0Hp Maxiglass/ Sand Filter, 7th season with Pool
    Painted cement finish repainted 2011
    400,000 btu Pentair Master Temp NG
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Robertshaw 700-511 Millivolt gas valve help!
    I am going to suggest you have a certified technician install your gas valve. I am all for fixing things yourself but gas valves are too important and if they fail or are installed incorrectly, it can be catastrophic.
    I worked with HVAC and heaters for 10 years.
    -- Guy --
    MJCP's Avatar
    Sep 2007
    Michigan
    129
    While I am not a certified hvac. I am licensed, in other trades and fully capable of doing this safely. But only after I learn the function of this unmarked, undocumented port.
    ps0303's Avatar
    Jul 2011
    FL
    3,703
    What model of Lite 2 do you have? Your Laars Lite 2 is probably not a millivolt heater and the gas valve, although a direct replacement, can be used in several replacements. I've used them before and just plugged the hole. If you don't feel comfortable doing that then find a valve for the heater you have.
    http://www.parts4heating.com/Teledyne-L ... s-s/38.htm
    A word of caution: When working with gas and other things you really might want to consider a licensed contractor. Consider the value of your life and others around you. I recently looked at a burned up heater at a customers house and found out he tried to trouble shoot it. He said he's not sure what he did but the unit caught fire. The unit is now toast and is being replaced. I'm only providing you with help but in many cases you need to hire someone. I realize people are all about saving money but lives are priceless!
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    MJCP's Avatar
    Sep 2007
    Michigan
    129
    It is an ESG SERIES 2. It is a millivolt system.
    Everything is the same on both valves with the exception of this port which is on the back.
    same inlet, outlet, pilot tube connection, terminal block, coil. Same btu rating. Same millivolt rating, same psi rating. Listed as the replacement for the current valve.
    I checked the installation literature and the part diagram does not show this port.
    I double checked the label on the valve to make sure it was the right one in the package.. it is.
    Just thought I'd ask here before sending it back in case it is just a duplicate pilot connection in a different location.
    Thanks
    Jun 2012
    western NY
    1,562
    When you compare the old valve to the new one...What is in the location of the second port on the old one. It is possible that this is a universal replacement with dual pilot ports, but I would have thought that there would have been some literature indicating this as well as a plug provided. I do recall years ago coming across this and it had all the warning stickers you could ever want plastered all over it warning of the need to use the provided plug to close off the unused hole. I do not recall the brand valve though. Do you have any pictures you could post of both valves? It would be nice documentation should anyone else ever come across this.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    MJCP's Avatar
    Sep 2007
    Michigan
    129
    The old valve did not have a second port. I will post photos in a few hours.
