Thread: auto pool cleaner and pop up heads question....
    Hello,
    I moved into a home about a year ago and it has the pop up cleaning heads on the floor of the pool. It seems the pool designer was an idiot, because there is no way to shut those off, the only way water gets back to the pool is by going through the floor cleaners. The pop up floor cleaners leave a lot to be desired when it comes to a clean floor bottom and manually vacuuming certainly gets old after a while.... I was hoping to be able to buy an auto pool cleaner, but with no way to shut those pop ups off i dont know if any cleaner will work? will the cleaners get stuck on them really easy? or is there one type of cleaner that will work better than another? any helps would be great ! thank you !
    25K gal, 18 x 36 rectangular vinyl pool, 1 hp WhisperFlo pump, Hayward sand filter, Barracuda vacuum, bleach, TFTestKit
    Mar 2012
    Mountain Brook, AL
    112
    Re: auto pool cleaner and pop up heads question....
    Welcome to the forum.
    I don't have the pop ups but many here do. I would say narrow it down to what type of cleaner you want (pressure, suction, robot) and a range of how much you want to spend. The Pool School link has an article, under Equipment, that discusses the differences. Your choice may depend on the size of pool and what type of debris you get. Once you know the type of cleaner then you can search and read all sorts of posts here discussing the pros and cons of each. Many of those articles tell if the particular cleaner does well with steps, ladders, pop ups, etc.
    13,500 gallon IG Diamond Brite Super Blue, Pentair Superflo 1.5 HP 2 speed pump, 300 lb Hayward Sand Filter, Hayward Swim Pure+ SWG, Four 4X20 Fafco Solar Bears, Jandy Lite2 NG Heater, Borates, Blue Diamond Robot, TF100 & Refills, Taylor SpeedStir
