Thread: Too much salt
    May 2009
    Trenton NJ
    497
    Too much salt
    Somehow I must have added too much salt. According to my aqua check strips I am getting a reading of 7.6 which is over the max limit of 7100 ppm stated on labels directions. My salt generator runs max efficiently @4000ppm. Do I need to drain some water or just leave it.
    The FC is steady @ 4ppm
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Too much salt
    Is your SWCG happy or mad? If SWCG is happy, no worries. But, if it is mad, then you gotta replace some water.
    You're done SLAMing when:
    May 2009
    Trenton NJ
    497
    Re: Too much salt
    Well the water looks great. The fc is where I want it. I know I am happy. I guess what I am asking is could it damage the cell with a reading that high?
    22,543
    Re: Too much salt
    If your swg isn't complaining I suspect a test error. 7100 ppm would not be good for your swg if it really was that high.
    Answer BF's question about whether your swg is showing any lights or warnings.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    May 2009
    Trenton NJ
    497
    Re: Too much salt
    Well I must of had a bad strip. I tested 2 more times and I am getting 4600. My swg max is 4000. So I guess it's good
