Results 1 to 7 of 7
Thread: Moving can our pool be empty and taken with us 12x36 summer
    We have a 12x26 summer escape metal frame pool we are moving this week. Will the pool make it. A pool store told me it will shrink do to the heat. It is running around 96 here in the late afternoon 60's in the mornings. Hoping to take it with us. Wonder how hard it will be to take apart too.
    Re: Moving can our pool be empty and taken with us 12x36 sum
    It depends on how old it is, if it is quite old there are more likely to be problems. Overall, the odds are fairly good that an above ground pool will survive a move intact.
    It is only 1 year old :P
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Metal expands in heat, not shrink. Sounds like they were trying to sell you a pool.
    Edit: Oops, your pool might not be metal walled. lol
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Absolutely can be moved........that is how they are designed. Just wrap everything up well, or store in large plastic containers.
    18x52 Ultra Frame with 1600 gph sand filter and intex skimmer
    carterj92's Avatar
    Jun 2011
    Columbus, GA
    90
    It can absolutely be moved. Just make sure to keep all the parts. Pegs and screws in baggies. ect. After you drain, just lay out the liner to dry out. We drain ours and store every year for the past 4 years. Its not very hard at all.
    5,061 Gallon 16' x 48" Intex Metal Frame Pool
    14" Intex 55Ib Sand Filter and Pump.
    _______________________________________
    Location: Columbus, GA Where the Heat and the humidity are* :)
    Yeah, I don't quite get that...These pools are made to be taken down each season. Just be sure the liner is totally dry before you fold it up, keep track of all the pieces, and make sure nothing punctures it in the moving process.
