Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 92
Thread: Test results are in with my TF 100, experts?
    Jun 2012
    Jackson, NJ
    105
    So I did throw in 2.5lbs of powder shock yesterday but removed all pucks from skimmers. Today I tested the pool and here are the results:
    FC 0.5
    CC 1.0
    TC 1.5
    pH 7.5
    TA 120-130
    CH 340
    CYA 100
    So what's my next step? I'm going to home depot now anyway so I'll be checking the thread periodically. Maybe I'll pick up some bleach?
    I/G Concrete w/spa 29k Gallons (I think lol)
    DE
    Nature2 thingy disabled
    Polaris 280
    Aqualink RS4
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Re: Test results are in with my TF 100, experts?
    I pick up bleach each time I go into town since I live in the country. Better to have too much than not enough I always say. But I am not the experts on here. I am a newbie and love this site.
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    You don't wanna hear this but............Your CYA is likely greater than 100. Do that test using half tap water and pool water and double your results. You should drain and replace water till the level gets into proper range for your SWG. Then you need to shock your pool using BLEACH! Also, noone here recommends use of the Nature 2 Thingy due to metals. Take a read through shocking your pool in pool school and see the CYA/Chlorine chart there.
    Butterfly's Avatar
    South Carolina
    10,045
    I think Leo has the TF100 XL
    Yeah, pick up plain unscented bleach or liquid chlorine. You are gonna need it.
    As Woody said, that CYA needs work. I suggest you retest the CYA using the dilution method. Use 1/2 pool water and 1/2 tap water, then the reagent and test again. You should double the test results. This is not accurate, but it will tell us if CYA is closer to 100 or 200
    You can pour the sample back and forth as often as you need to help confirm your reading.
    Have you seen the Extended Test Kit Directions? extended-test-kit-directions-t25081.html
    You're done SLAMing when:
    Jun 2012
    Jackson, NJ
    105
    I do have the XL version yes
    My CYA testing was interesting because I kept adding the water and kept seein the dot, not very well but I did see it so I'm assuming it was 100. Even going further I could still see the outline of the dot but it was so murky I decided to say it was 100.
    DE
    Polaris 280
    Aqualink RS4
    Jun 2012
    Jackson, NJ
    105
    Oh and I don't have SWG.
    DE
    Polaris 280
    Aqualink RS4
    38,271
    Wait it sounds like you filled the CYA tube and still saw the dot. Is that right? That would mean you have low CYA.
    Just want to bee sure before you drain.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Jun 2012
    Jackson, NJ
    105
    No I could still somewhat see a very murky dot when I was at 100ppm but started to doubt myself and just said it was 100ppm.
    As a side note: the water is crystal clear and sparkling lol.
    DE
    Polaris 280
    Aqualink RS4
    30,415
    That really does sound like you may have made a testing error. A CYA reading of 100 will mean that you would have put about 1.25" of water in the tube and the dot disappeared completely.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by AdrenalinPlease
    There is a link in the CYA Extended Test Kit Directions (in my post above) that has pics of the test. It may help you get a better read on the test. Many of us have a better handle on the test after viewing the pics.
    Very good news
    you should not see the dot at all. you can keep pouring back into the bottle so you can experiment with the test. Really go until you cant see the dot at all.
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    Jun 2012
    Jackson, NJ
    105
    I will retest tonight again.
    Picking up Austin's Pool tech liquid chlorine 12.5% 4 gallons.
    DE
    Polaris 280
    Aqualink RS4
    Jun 2012
    Jackson, NJ
    105
    Can I just take out the cartridge from the nature2 thingy?
    DE
    Polaris 280
    Aqualink RS4
    30,415
    Absoloutely.
    Jun 2012
    Jackson, NJ
    105
    Should I add some of the liquid chlorine tonight?
    DE
    Polaris 280
    Aqualink RS4
    38,271
    If you are going to replace water realize you will be pumping out whatever chems you add.
    Butterfly's Avatar
    South Carolina
    10,045
    I suggest that you do add some, maybe 10 PPM FC. Until you can confirm the CYA test, my opinion based on your description is that your CYA is maybe low, not high.
    Jun 2012
    Jackson, NJ
    105
    I didn't add any as I already left and my filter doesn't run overnight. Programmed to run all day though so I'll add it in the morning. I'll redo the all the tests in the morning and try to be accurate.
    DE
    Polaris 280
    Aqualink RS4
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Image A
    Image B
    Image C
    If you fill the CYA testing tube completely, does it look like Image A, B or C? The tube in the images is part of the chlorine test block but the tubes work in the same way.
    I read and re-read the postings and it's not clear what you meant.
    -- Guy --
  20. Back To Top    #20
    Jun 2012
    Jackson, NJ
    105
    I added half a gallon of the 12.5 liquid chlorine this morning. Will test in a little while to see the full scope again
    DE
    Polaris 280
    Aqualink RS4
