Results 1 to 7 of 7
Thread: I think I made a mistake
    I followed the directions for adding borates. I did 1/2 so far 24lbs and added 24lbs of borax and 189 oz of muriatic acid. But the test stips the pools store sold me do not test for borates just bromine. Is the pool safe to swim in today since I can't test for them? I am getting ready to retest the pool for fc, ph, ta etc. It is to late to go back to the store as we are having a pool part today with friends and family today. Hate to have a pool party without the pool.
    AG 15x30 4 ft deep 12000 gal.
    Aqua Star 100lbs Sand Filter model fs019
    Installed june 2012
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: I think I made a mistake
    zeroturn:
    The amount of borax you added (24 lbs or 384 oz by weight) increased the borate ppm by 25, per the Pool Calculator ( I used 13,000 gallons, splitting the difference between 12,500 and 13,500 per your sig). Borate levels below 50 ppm are considered safe to swim in. If you had between zero and 25 ppm of borates before adding, you have no worries.
    As for the MA addition, I cannot comment on that since I don't know what your pH level was, other than to state that MA can be used to compensate for the pH rise when adding borates.
    BTW, here is a recommended borate test strip: http://tftestkits.net/Borates-Test-Strips-p29.html
    Bromine test strips aren't going to help
    As long as you can test the PH and make sure it is in range you are totally fine.
    Thanks. I'm loving the pool store more and more as time goes buy. I told them what I wanted they assured me it was that. I didn't double check. So in the end it was my fault. Family had a good time and I ordered the correct strips online. I'll wait to put the rest in untill they arrive. So glad I found this site. Thanks a bunch
    Installed june 2012
    Jan 2010
    Randleman,NC
    620
    Never trust the pool store's.You need to order you TF-100 get from Dave..You will get your money back within the season..Then you know what your water is&know how to adjust yourself.Pool School is the best thing to study up on..
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    I already have the kit best thing I bought. For the first time I can read the results. Those test strips had me guessing all the time.
    Installed june 2012
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by zeroturn
