Thread: New Here and New Owner..
    Hey everyone,
    The wife and I just bought a house with a 13,500 gallon in-ground pool. It is straight chlorine at the moment. The pool currently has a Hayward C9002 Star Clear Plus Filter and a Marathon Electric 1HP 3450 RPM Pump. The Pool was put in about 15 years ago and I assume the equipment is all original.
    The filter cartridge for the Hayward def needs to be replaced so i am going to order one of those.
    A friend owns a company that produces SWGs so I will have that next week to switch it over.
    My question is with the amount of time that has passed, is there a better filtration system that I should switch to while I am changing it over to Salt, and also is there a more efficient pump system I should be looking at?
    Thank you in advance,
    Dan
    Re: New Here and New Owner..
    Welcome to TFP!
    A two speed, or perhaps variable speed, pump will reduce your electrical usage significantly. However, it is rarely worth replacing a working pump until something goes wrong with it.
    Thank you, I was actually just looking at the variable speed pumps. They are not cheap, so I think you are right on if it is not broke don't fix it. However, if I wanted to look at them, what brand is recommended?
    Also, beyond the recommended type of filter system I should be using, if you think I am okay sticking with the Hayward filter I have, is the 90 sq ft model I have large enough for my pool?
