Thread: Test results now what?
    May 2012
    Tulsa, OK
    14
    OK my water is clear but I tested everything today. Here are my numbers
    FC 2
    PH +7.8
    TA 130
    CH 260
    CYA 30
    Do I need to add anything to get my TA or Ph down? I know I need to add Chlorine.
    Kendal
    25,000 gal, sand, IG, gunite with attached spa and waterfall
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Test results now what?
    Yes, you need to lower the pH to about 7.2. Each time the pH reaches 7.8, lower it to 7.2. Over time the TA will come down.
    Since the CH is near the min, I suggest that you raise it to about 300 when you get time. No hurry, but a few backwashes might put CH a little low.
    You're done SLAMing when:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Yep, lower pH. And you're right about adding some more chlorine.
    Consider raising CYA. You're in the enviable position where you can use trichlor pucks in a floater for a little while. They'll slowly raise CYA, maintain FC levels (you should still test it), and keep pH in check (test that, too). You're okay for up to 8 lbs worth of pucks. So don't buy the huge drum, even if it's on sale. And save a couple for when you're on vacation.
    My two cents
