Thread: Lower TA
    Lower TA
    Here are my current numbers with the TF-100 test kit:
    16,000 gal. Fiberglass pool
    Pump runs 12 hrs a day with the SWG at 60%
    FC - 4.5
    CC - .5
    TA - 100
    CYA - 50
    PH - 7.8
    I can't seem to get my TA to lower. I have spa jets in my pool and they have been on just about everyday for the last 2-3 weeks and every now and then I have my waterfall on but the TA doen't want to go down.
    Any thoughts?
    Leisure Pools - Rivera (16,000 gal.)
    Pentair System: IntelliChlor IC20, Clean & Clear Plus Filter, MasterTemp 250 Gas Heater, SuperFlow Pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Lower TA
    TA lowers with acid. It also lowers pH. Aeration raises pH back up.
    So the answer is more acid. Adjust pH down to 7.2 and you'll lose a little TA. Then let pH rise again or aggressively aerate and repeat.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Lower TA
    Yep, and here's a link to the directions in Pool School:
    pool-school/lowering%20total%20alkalinity
    You're done SLAMing when:
