Results 1 to 9 of 9
Thread: Skimmers
    Skimmers
    I have noticed that the skimmers do not seem to be letting the water go through to the pump as it should. Does anyone have any suggestions on what I can do to fix this?
    Thanks
    Timie
    ~15,000 gal. IG marcite, 120 sq. ft. cartridge filter, 1.5 hp pump, Nature2 Express, 1 skimmer, 1 floor drain, 2 returns
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    How are you determining this? What happens when you close the (if you have one) main drain valve slowly?
    Quote Originally Posted by JohnT
    The skimmer shuts off. I just finished backwashing and the DE goes in slower. In order to have the Baracuda work I have to have both skimmers on and the main drain shut off. The pressure of the filter is around 30. It is usaully around 15 to 20
    A good thing to try is to use a drain king, an attachment for garden hoses for clearing blocked pipes. You should be able to insert it into the intake pipe by removing the pump strainer basket, turn off the main drain and if possible the other skimmer, and then turn on the garden hose. That should flush any debris back towards the skimmer.
    SW Indiana
    9,199
    Quote Originally Posted by timie
    A restriction in a skimmer or drain line will give you a lower pump pressure reading. High filter pressure indicates a restriction after the pump. Could be dirty grids on your filter. A restriction in the line after the pump still results in lower flow from skimmers.
    I had cleaned the filters so the filter is clean. I have been fighting a bad algee problem and am still having problems. I have added bleach and shock but the pool is still cloudy. I backwashed earlier today and still the same thing. I just now finished blowing the lines to the skimmer and the skimmer seems to be a little better. Could this have anything to do with why my baracuda (brand new) is not working properly? It indicates that there is not enough suction
    Feb 2008
    Denton, TX
    5,061
    Is your Baracuda on a designated suction line or do you have it routed into one of your skimmers?
    Also, be sure to get yourself a leaf trap for your Baracuda. Without one, you can clog your suction side in a bad way.
    Craig
    Quote Originally Posted by 257WbyMag
    Craig
    It is on a designated suction line. Both skimmers have to be open for it to work. Where do you get a leaf trap and how much are they?
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    I suggest you tackle the algae as a seperate problem. Keep working on your skimmer issue, but don't let the algae keep going. You can't just throw in some shock and hope for the best.
    Allow me to suggest a little reading...
    Start with this thread: http://www.troublefreepool.com/sticky.php?s=4953
    Then this one: http://www.troublefreepool.com/sticky.php?s=4147
    Then come back with a full set of test results, and questions.
    Otherwise, all the effort spent trying to help you will just be shots in the dark. If you don't believe me, read this thread:
    http://www.troublefreepool.com/sticky.php?s=3662
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
