Thread: Help removing flow diverter disc form solar panels???
    Can someone please tell me how can I remove the flow diverter disc from my Sunheat solar panels? I would like to connect them in parallel. The discs are located right in the middle of the intake pipes, so getting to them will be hard. Thanks!!
    Intex Ultra Frame 24' Round
    Sun-Heater 4'x20' Solar Heater
    Hayward EC-50 D.E Filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Help removing flow diverter disc form solar panels???
    Sorry I missed you post. It is easy to remove them. I removed mine using a piece of black iron pipe that fit loosly inside of the manifold to punch it out. They separate real nice form the inside manifold wall (I have done 6).
