Thread: 12.5% in the Houston area?
    Anyone know where I can get the 12.5% in the Houston area? I've only found 10% at a few places.
    Jun 2012
    Central Ohio
    14
    Re: 12.5% in the Houston area?
    Check your hardware stores (Lowe's, Home Depot), I found ours at Menard's but doesn't look like you have any of those there. I also found 10% at WalMart. Our pool store had the higher % too but it cost more there.
    15,360 gal/IG/Vinyl/Sand/Hayward Pump 1HP/SWG
    May 2011
    Orange, TX
    66
    Pool Warehouse. We have one in Beaumont, thus I assume there is most likely one in Beaumont. Leslies also carries it, as well as Lowe's from time to time. Although i question how old some of the stuff is at Lowes.
    20,500 gallon free form, 6X9 hot tub w/ spillover, 18" jumping platform w/ 3ft shear descent on chopped rock, Travertine coping, 2.5HP Hayward 2-speed filter pump, 525 Hayward Cartridge filter, 350K BTU Hayward NG Heater, 2HP Hayward water feature pump, Satin Matrix Northshore Carribbean, Jandy PDS-8 Controls
    Thanks guys. I've been doing well with 10% so far but will check out the big box stores this weekend.
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    The Home Depot near me in Spring only had 10% and it was not as good a value as the 6% bleach.
    18,000 gallon in ground, plaster - completed 6/29/12
    Jandy 340 sq ft cartridge filter
    Jandy variable-speed 2 HP pump
    Jandy LXi 400 heater
    Jandy Aqualink PDA-PS4
    May 2014
    Houston, TX
    155
    Bump, any 12.5% deals in the Houston area? I haven't been able to find any.
    IG gunite pool size: 12,500 gallons - includes spa with spillover, Polaris vacuum cleaner, Ultrapure Ozonator, inline tab chlorinator that I no longer use
    Filter: Hayward Swimclear Model #4030, 4-Cartridge Filters
    Pump: Century, 2 HP with a Hayward 6060 booster pump
    Date of build: March-April 2014 *NEW* : Test kit: TF-100
