Results 1 to 8 of 8
Thread: Aerate water
    Aerate water
    Yeah.. I need/want to aerate my water, to raise the pH, doing everything right according to the calculator from now on. I can't think of a good way to do this however. I have a 1/4hp sub pump at my disposal, or I could just buy a fountain, but yeah might as well use what I have if I can. Does anyone have a link to a thread or any idea what I can do to get some aeration going?
    EDIT - Oh dang my sub pump says specifically do not use in swimming pools
    30,000 Gallon, Above Ground, Vinyl, DE Filter
    38,267
    Re: Aerate water
    There are lots of threads with pictures of home built fountains. Use the search option at the top. Generally just some PVC pipe connected to your return.
    Another option is blowing air into the water with a compressor.
    Jan 2010
    Northern Virginia
    282
    Re: Aerate water
    Here's one I just posted today.
    Very easy provided you have a spigot attached to your pump/pool piping system:
    cheap-and-easy-aerator-to-lower-t-a-but-slow-going-t48638.html
    700 sq. ft./30,000 gal, gunite pool; 48 SF DE filter; 1.5 HP pump; Salt Water Generator; Solar Heat
    Jun 2012
    Phoenix, AZ
    29
    Re: Aerate water
    I bought a 1/6hp submersible pump to drain half my pool water (err.. the first time). I recently used it again to get my salt/cya/ch down (drained about 1/2 again). After I found this site and figured out what all I was doing wrong I started trying to straighten things out.
    I have a built in "aerator" but it doesn't do much as far as I can tell. It's a ~1/2" line with a semi-circle cut in an end cap, which basically makes a fan of water. I figured as long as I had dug my pump out of storage I could use it to aerate. I started with just using it on the 2nd step and letting it push the water up. I eventually got a PVC hose fitting, and a 2' piece of 3/4" PVC and attached it to the pump. I still have it on the 2nd step but I use that to aerate for a few hours each day. It shoots the water straight up a few feet. It's my poor man's fountain.
    Not sure if my pump is rated for pools but it seems to do OK. Like I said I've used it twice to drain my pool and it's still going.
    CLB
    12,000 gal Plaster, Aqua Rite SWG, Hayward Super II, Sta-Rite HRP Sand filter, Hayward Ultra Vac, TF-100.
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Re: Aerate water
    http://www.troublefreepool.com/downl...7737&mode=view
    See if that picture helps give you ideas? I posted that a while back showing how Skippy fashioned the sump pump at one end of the pool while the other end has the fountain going.
    I'm all for using what we've got and saving a dime
    30,414
    Re: Aerate water
    , to raise the pH,
    How about 20 Mule Team Borax?
    read "The ABC's of Pool Water Chemistry" up in Pool School
    Re: Aerate water
    , to raise the pH,
    I have, I'm following the pool calculator right now though, I only need to raise it .3
    Quote Originally Posted by YippeeSkippy
    That's what I'm talking about.
    Jun 2011
    Savannah, NY
    16
    Aerate water
    Here's what I made too aerate with.
    16' x 32' rectangle with 4' radius corners.
    Approximately 19,200 gallons
    Hayward sand filter and pump
    ColorQ Pro 7 Test Kit
