Results 1 to 1 of 1
Thread: Need help on my equipment list - Riviera 40
    First off, this forum rocks!!! I have learned a lot that has helped me decide on my pool and PB. I am ready for the final dose of knowledge, but need it customized to my situation. I would greatly appreciate any help/advice. Once I start the build, I will post pics. It will be a while though b/c my PB is booked till Sept.
    I am rounding the corner to finally make a pool purchase. I have decided to get the Grand Riviera 40 from Leisure Pools. I would like some help deciding on a few upgrades. Attached is the dig spec list, and the pool / deck design. 16x40 22,600 gal.
    The price is $36,000 with the following included in the kit.
    > Hayward 1.5hp single speed pump (model # unknown)
    > Hayward cartridge filter (model # unknown, but am positive its too small)
    > Hayward Aqua Plus automation w/ SWG
    > 2" plumbing, everything individually plumbed
    > ~430 sq ft. decking
    > 2 main drain, 1 skimmer, 3 returns, 2 suction (I think the return / suction is in the correct ratio, it may be reversed)
    > Electrical included
    > Water
    > Backfill w/ gravel
    We are adding an additional 300sq ft decking, Rico Rock coping, 3 lights in the side, diving board, retaining wall / firepit
    I want to upgrade the pump to a Hayward 2-stage pump, don't know which one though. No hot tub, water features, slide, solar heat, etc - just a hole in the ground with water in it. Electricity is cheap here ~$0.09. What are your suggestions?
    I know that the filter needs to be upgraded. Either the 425 or 525 sq ft - its a new build so pad space is irrelevant, it will be built to match the equipment. What model # corresponding with the recommended pump?
    Also, it that enough skimmer / suction / return for the size of the pool?
    Thanks again for the advice.
    [attachment=1:2v98plh7]Grand-Riviera-40.pdf[/attachment:2v98plh7]
    [attachment=0:2v98plh7]Pool design.pdf[/attachment:2v98plh7]
    Attached Files Attached Files
