Thread: Pump basket
    May 2012
    Pleasanton, California
    15
    Pump basket
    My pump basket has leaves and debris in it. When I shut off the pump and open the filter valve to remove the pump cover, all the debris is pushed back into the pipes where I can't retrieve it. Is this happening to others, or is there a fix?
    Oct 2011
    Minnesota
    164
    Re: Pump basket
    Shut the valves off before opening, and the debris will not move. The pump will also not lose its prime.
    20x44 IG vinyl. Intelliflo, Pentair Cartridge Filter (420ft^2), Raypac 336K, Kreepy Krauly
    38,475
    Re: Pump basket
    Assuming this in inground pool and the pump is above the water level?
    You need to shut a valve between the pump and the pool so the water does not flow back to the pool.
