Results 1 to 11 of 11
Thread: how much bleach a day..???
    I'm doing a half bottle of bleach a day... Is that normal? All my numbers (except chlorine) are good according to the pool calculator. My free chlorine is 1.5. Pool is clear.. Should I shock?
    22x52 intex pool with swg and sand filter.
    Feb 2012
    Cypress, TX
    131
    Re: how much bleach a day..???
    Why are you having to use bleach at all with a SWG? What is your CYA level? I think we need a bit more information to help. Do you have one of the recommended test kits? What does your water look like? What is your CC level?
    23x40 freeform w/spa, 28,000 gal. PCC-2000 in-floor cleaning. Pebble Sheen w/flagstone coping. 14' weeping wall, (2) 18" sheer descents. Sta Rite- cart 400 sqft. filter, Intellipro VS pump, 1hp (cleaning)2hp (water feature)Max E Pro's. Easy Touch 8 function w/IPod. Rainbow chlorinator, Paramount Clear O3 (I know, I know), Max-E-Therm 400K heater.
    38,239
    +1 to everything Bluechip said.
    Posting a full set of results and giving us more info about your situation will help us help you.
    I have a pentair 78hr & chlorine pro rest kit. I test with both, just in case. I would like not to have to buy another one till these are used : )
    #s from tonight's test
    Total chlorine .5
    FC .5
    Ph 7.7
    Ta 110
    Ca 30-50
    Water temp 90
    my water is clear.
    My chlorine is just always tests low- if your swg doesn't keep up, then you use bleach.
    I'm running my swg 7 hrs a day
    It's HOT here - upper 90s to 105 past 2 weeks.
    Thanks
    38,239
    What is your CYA? Is that what you reported as CA?
    If so that is too low. And if your SWG still does not keep up then you just have to run it longer.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Yes CYA is ca ... The pool calculator says 40 for my pool ... Maybe I'm reading or doing something wrong ??
    Okay. I'll up the swg run time by a couple of hours and see if it can keep up.
    Thanks.
    What do you think my CYA/ca should be?
    What and how much should I add?
    38,239
    Did you set at the bottom that you are using a SWG?
    We recommend for SWG pools a CYA of around 70ppm.
    That was one problem... : ) when my swg wasn't keeping up, I changed it to bleach to see how much to add. I hadn't changed it back. I have changed it back now and will add stabilizer tomorrow.
    Tank you.
    Aug 2011
    Virginia Beach
    295
    Just remember that CYA takes up to a week to register on a test.
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
    Yay! I have FC 5 - now -- I know that's still low, but at least it registering : ) I added the stabilizer via the sock method yesterday and have gone from .5 to 5.
    My other #s
    Ph 7.7
    TA 120 (high)
    cYA shows 80 - but I just put it in yesterday - so I'm paying no attention to this # for about a week?
    Water temp 86
    Thanks.
    38,239
    Well I hope the CYA does not go too much higher.
    Once the FC gets stabilized you could start to try to lower the TA to help hold the pH down if you notice a constant rise. See article in pool school.
