Results 1 to 10 of 10
Thread: Wanting to convert - Chlorine to SWG - best way? DIY ?
    Jun 2012
    Lafayette, Ca / USA
    260
    A friend had their pool professionally converted to SWG after they drained & replastered. All I can say is WOW ! What difference to swim in. So nice on the skin. (I *am* curious whether the daily/weekly/monthly testing is the same though - or more involved or more frequent).
    So if we were to convert our existing IG Pool to SWG, are there step-by-step guidelines or documentation anyone can point me to that describes how difficult this is to do? From what I've seen, it requires a "cell" and a special "pump", right? Sounds easy enough to cut the PVC and put this in-line, right? Then there's the whole BBB balancing act to follow of course. From what I've read here, no need to drain the pool to do this - just convert, test, and adjust.
    thanks in advance
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: Wanting to convert - Chlorine to SWG - best way? DIY ?
    This is really not a conversion, but a chlorine methodology change. The SWG makes chlorine from salt water.
    1. Add SWG to return side of pool filtration
    2. Add a bunch of salt to your pool (3000 ppm or so) via Pool Calculator
    3. Run pump for 24 hours
    4. Turn on SWG
    5. Test
    Testing involves adding an additional test for Salt, but you do not have to do this very often, as the chlorine generated turns back into salt, which is part of the beauty of the system. CYA needs to be somewhere between 60 -80, as the chlorine dose from the SWG is low and steady, so you want a fair amount of CYA protecting the chlorine long enough to sanitize your pool.
    We recently went through this conversion, and have been happy with it thus far. Water is very soft. Chlorine levels are fairly low. We have had to watch the PH, as it has tended to creep up a little these first few weeks.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Jun 2012
    Lafayette, Ca / USA
    260
    Thanks so much .. (so much great info here ...) !!
    Oct 2011
    Minnesota
    164
    Also, you could add salt to get the same feel, but maintain as you currently are doing.
    20x44 IG vinyl. Intelliflo, Pentair Cartridge Filter (420ft^2), Raypac 336K, Kreepy Krauly
    Jun 2012
    Lafayette, Ca / USA
    260
    I just wanted to eliminate the physical need to ADD Chlorine Bleach ... yea, I get it that the by-product of the SWG is in fact Chlorine. thanks again.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Compupool CPSC48 can be delivered for less than $750. I did then install in about an hour. Here's the link of my install: cpsc48-install-mostly-new-reports-of-pool-conditions-t32089.html
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by cody21
    I wouldn't call it a "by-product"...chlorine production is the reason to install a Salt Water Chlorine Generator (SWG).
    Jun 2012
    Lafayette, Ca / USA
    260
    Yea, I get that ... Thanks again for the direction and help .... Chatting with the previous Pool Maintenance peeps they are clearly against SWG systems .. Claim they're more trouble than they're worth .. hmmm ... I guess we'll make a decision at some point .. Likely just deal with it as regular Chlorine pool this year and get used to the testing & balancing of chems .. then revisit this next year.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    That could be a profit margin motive for them....meaning once up and running what do you need them for?!?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    You will find many users of them on here and not many will agree with those peeps. There are not many drawbacks, on is if you have soft stonework around you pool, then they are not a good choice...ohhh, and the initial cost.
