Results 1 to 9 of 9
Thread: Summer Escapes pool with intex sand filter
    I wanted to upgrade our summer escapes pool (15x42) to the intex sand filter (sf15110) but cant figure out the setup.
    What would be the best way to modify the the fittings, without having to cut the pool to accept the new parts from intex.
    Oct 2011
    New Caney, Texas
    414
    Re: Summer Escapes pool with intex sand filter
    Welcome to the forum
    There is a lot of good info here: http://www.troublefreepool.com/usefu...rs-t29612.html
    And if you Google you can find adapters made to do just that.
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    carterj92's Avatar
    Jun 2011
    Columbus, GA
    90
    You can kind of rig it to work. summer-escapes-pro-series-13-x22-rectangular-questions-t43440.html
    Just scroll down a little bit and there are pics of someones setup.
    5,061 Gallon 16' x 48" Intex Metal Frame Pool
    14" Intex 55Ib Sand Filter and Pump.
    _______________________________________
    Location: Columbus, GA Where the Heat and the humidity are* :)
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    I think this might be the adapter you need.
    http://www.intexcorp.com/index.php/10849.html
    You'll also need the 1 1/4 inch hose clamps too, if you don't already have them.
    Intex 18ft x 52in Ultra Frame Pool, hard plumbed w/skimmer and fountain
    Intex 4000 gph cartridge filter pump
    Intex SWG
    Quote Originally Posted by schertzy82
    I was hoping Home Depot sold something similar to that.
    Quote Originally Posted by carterj92
    I saw that setup but was alittle stumped because I dont have an in the wall skimmer.
    I used a 1 1/4' pipe that fit perfect on the pump and used a reducer to go to the 1 1/2 and the went up again to 2'.
    13500 gallons
    Intex 2650 Sand filter pump
    AG
    What skimmer do you have?
    13500 gallons
    AG
    Quote Originally Posted by wwhite0310
    I dont have a skimmer I'm upgrading to the intex sand filter from anintex model 637r
