Thread: Cheap and easy aerator to lower T/A (but slow going!)
    Jan 2010
    Northern Virginia
    282
    I needed to lower my T/A but didn't have adjustable return jets that I could point up toward the surface. Someone in here suggested that if I had a spigot attached somewhere along my pump/filter lines I could use that. As luck would have it, I did have a spigot in place and I set up a low budget aerator. Here it is in all of its glory:
    I just cracked the valve on the hose open a bit to blast a fine mist out over the pool.
    It's hardly a quick process, but my T/A is coming down:
    Date.....T/A
    5-13.......210
    6-3........180
    6-10......170
    6-17.....160
    6-23.....140
    Just a little FYI for anyone out there with a similar problem.
    700 sq. ft./30,000 gal, gunite pool; 48 SF DE filter; 1.5 HP pump; Salt Water Generator; Solar Heat
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: Cheap and easy aerator to lower T/A (but slow going!)
    At least the acid is handy to lower the PH back down!
    Jan 2010
    Northern Virginia
    282
    Yep! It's a two for one shot with that photo!
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Do you have a squeeze-to-spray type hose nozzle? I bet if you put that on there and pointed it straight down, it would work even better!
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Once I finally get our pool up and hard plumbed I'm planning on using an old shower head we have laying around for aerating and water feature duty. It's one of the adjustable type with pulse and different sprays. It had started leaking and the DW bought a new one. After I replaced it I found what was wrong with it and it should work as good as new. If not we still have the original shower head that was never installed when we built the house, it just doesn't have all the fancy features. I've seen several threads about drilling pvc to create water features, but decided not to reinvent the wheel.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Jan 2010
    Northern Virginia
    282
    Quote Originally Posted by msgtdan
    Yeah, I saw them too and probably would have gone that route, except I don't have any threads on my return lines, just smooth pipe. I couldn't figure out an easy and effective way to attach anything onto the return so I went the hose route.
