Thread: Can i trust the pool store to give accurate testing ?
    just want to make sure , what my levels are , cheap test strip, is showing high CYA
    Feb 2008
    Denton, TX
    5,061
    Re: Can i trust the pool store to give accurate testing ?
    If you don't have a good test kit, then having the pool store run the tests is better than strips. Please consider getting yourself a good test kit such as the TF 100 or the Taylor K-2006 from tftestkits.net.
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Pool store testing can serve a purpose, but the advice on this forum is based on accurate self-testing with a good test kit. No one will take care of your pool or know your pool like you do, so the first bit of advice is to get yourself a good test kit and only then, you can trust your test results and be in control of your pool.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    Jan 2010
    Northern Virginia
    282
    Agree with the above. Get a good kit and learn how to use it. It's intimidating at first, but quickly becomes second nature.
    I've gotten some very inaccurate results from my pool store, but maybe your is better than mine.
    700 sq. ft./30,000 gal, gunite pool; 48 SF DE filter; 1.5 HP pump; Salt Water Generator; Solar Heat
    Will get a reading from pool store , also going to buy a real test kit .
