Thread: quick question
    Liteguy's Avatar
    Aug 2011
    Cave Creek, AZ
    49
    quick question
    Gents,
    I've got CH reading of 300+, in a SWG 13K gallon pool
    A. Do I need to worry about it?
    B. If so, how to reduce?
    Thx in advance
    steve
    Steve-Liteguy
    13K Pebble-tech Pool, ECO pump, IntelliChlor SWG, DE
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: quick question
    300 is no big deal. What's with 300+? Are you using test strips?
    Unless you live near San Diego or Phoenix where reverse osmosis is available, your only solution is to partially drain and refill. And then rebalance everything, including salt.
    Liteguy's Avatar
    Aug 2011
    Cave Creek, AZ
    49
    Re: quick question
    No test strips, I'm using the TF test kit, sorry I couldn't get an EXACT reading, but know it's over 300.
    YES Cave Creek, North of PHX
    Water is a fresh fill
    Well water is used to displace evaporation and well water is hard.
    Steve-Liteguy
    Richard320's Avatar
    Jan 2010
    19,046
    Re: quick question
    Check this thread: reverse-osmosis-t45297.html
    Liteguy's Avatar
    Aug 2011
    Cave Creek, AZ
    49
    Re: quick question
    Richard, thanks for the link, with the high evap rate here, looks like I'll live with what i've got and keep the chems inline, thank you...
    Steve-Liteguy
